01-05-2012, 08:27 PM | #1 |
Rep 37
Windscreen washers not working properly.
Used my windscreen washers the other day and this little dribble came out. The solution is simple and doesn't cost a cent. Remove the washer container. It is held on by one bolt at the top. Take out the two pumps. Blow through the hose attached to the pump which is where gunk can build up and block the flow. Reinstall and test. Very simple. Thought I would share.
01-07-2012, 12:19 AM | #2 |
Rep 48
At one time I had an entire civilization of green slim in the bottom of the container and had to kill off billions to get it working again :-)
X3 3.0d 2006 update, DVN-E83 GPS with reversing camera, Alpine SPS410 in doors, Earthquake SWS-8X (4ohm) under seat driven by Alpine PXE-650 and Pioneer GM-D9500F amp, Superchip ECU remap.
