01-02-2013, 09:04 PM | #1 |
Rep 323
OEM X5 Wheels
Does anybody know if OEM X5 wheels will fit the X3? I like the style 214 rim and think it may look good on the M Sport but I'm not sure. Has anyone done it?
01-03-2013, 06:30 PM | #2 |
Rep 427
I was told by the SA the offset will not fit our X3 brakes.
2013 X3 3.5i AW,Msprt,rear fogs,PS,CP, Tech, etc...
Other cars 2005 S2000 2018 i3S |
01-04-2013, 06:59 AM | #4 |
Rep 11,843
Drives: MY24 G01 AW Msport
im sure the theres reps of oem, check ebay.
01-04-2013, 02:43 PM | #6 |
Rep 983
From an old post by Lotus7:
Basic wheel specifications for the X3(F25) chassis are: Bolt Circle = 5 X 120mm Offset = 45mm (43 to 47mm acceptable) Hub centering Bore = 72.5 mm (hub ring dia. = 72.47mm) Bolts = M14X1.25 Spherical seat, 17 mm heads (Note the X3(E83) uses M14X1.5 bolts) Minimum bolt engagement = 9.5 turns |
01-04-2013, 05:37 PM | #8 |
Rep 2,527
google
Front alloy wheels: 20x10" ET40 Wheel part number: BMW 36116772249 Rear alloy wheels: 20x11" ET37 Wheel part number: BMW 36116782916 e90post has a wheel size calculator on its Wheels/Tires section and here is what it says: " 16mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 22mm" |
01-04-2013, 05:58 PM | #9 |
Rep 323
So I may be able to use a ~5mm spacer and a hub ring to get them to fit, but they may stick out an extra inch from where they do now. I'll have to look and see where the stock wheels stick out to and see if an extra inch will look good or if it will stick out from the fender too far.
01-09-2013, 02:21 PM | #10 |
Rep 554
Drives: 335D MSport 2016
I think the hub centering bore is bigger on the current X5 but the previous X5 wheels fit, I have them on mine for winter
01-09-2013, 02:33 PM | #11 |
Rep 323
