04-22-2022, 03:26 AM | #1 |
Rep 56
Center Console Leather Trim Part
Hello everyone. Does anybody know the part#, if it even exists, for the leather trim that surrounds the center console on the sides on both driver and passenger side?
EDIT: In black, not red! Last edited by OppaDoggy; 04-22-2022 at 12:12 PM.. |
04-22-2022, 03:43 AM | #2 | |
Rep 914
If it's Fiona Red then I think part number is 51168074770 assuming no change between pre-LCI and LCI. Tacora Red is 51169493699 Last edited by strike4A; 04-22-2022 at 05:05 AM.. |
04-22-2022, 08:11 AM | #4 |
Rep 912
Drives: 2022 X3 M40i LCI
Looks like you can. Not cheap though. About £460 for a pair. I wonder if this is available in black with blue stitching?
https://www.fixparts-online.co.uk/en...168074770.html
2022 X3 M40i LCI. Brooklyn Grey Metallic. Driving Assistant Professional. Black with Blue Stitching Vernasca Leather M Seats. Comfort Pack. Pano Roof. OEM Carbon Fibre Interior Trim. 21” 718 Alloys.
04-22-2022, 12:13 PM | #5 |
Rep 56
05-29-2022, 04:46 PM | #7 |
Rep 2,115
https://x3.xbimmers.com/forums/showp...43&postcount=7
Supposedly this picture is from x3. Maybe this was individualized option from the factory. |
05-29-2022, 04:49 PM | #8 |
Rep 2,115
05-30-2022, 10:08 PM | #9 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3552
Rep 4,244
You would have to replace the whole center console. Not very affordable or realistic to replace just for 2 leather pieces in my optimism.
05-31-2022, 01:55 AM | #10 |
Rep 912
As in a pair of the leather trims, one for each side = 2 or a pair,
No you don’t, you can just purchase a pair of leather panels. Check the link above I posted!
05-31-2022, 02:30 PM | #11 | |
3552
Rep 4,244
05-31-2022, 04:14 PM | #12 |
Rep 912
It’s the link to the leather panels with a part number and price. What more do you need? What do you want to look at pictures for? You know what the part looks like.
05-31-2022, 04:32 PM | #13 | |
Rep 2,115
If X4 fits on X3 for center console then yeah, if you can match the same leather code as one has in X3. Anyway, mine (MAPQ) doesn't even show up. |
05-31-2022, 09:19 PM | #14 | |
Rep 2,115
This part # is what i need with MAPQ=yes, 51169493701 US $390. Only question is, does pre-LCI X4 and X3 have same profile, fitment for center console... shite... |
05-31-2022, 09:50 PM | #15 | |
3552
Rep 4,244
The part you keep referring to is the entire console, not just leather panels. You can not just get the panels around the center console trim. The link you provided is useless for what I was even stating to you in the first place. The X4 console is not the same shape as the X3 console anyways. |
05-31-2022, 09:54 PM | #16 | |
Rep 2,115
I was all set to order, and read up on replacing the again, whole center console in TIS, looks easy enough. Then you say, x4 != x3 for center console? What's interesting is that F97/F98 X3 use the same center console part numbers as G02 X4. What's up with that? |
06-01-2022, 12:30 AM | #18 | ||
3552
Rep 4,244
06-01-2022, 06:30 AM | #19 |
Rep 501
This is my car, an X4 M40i with the carbon fiber center console from a X3M Competition as mine is a 2021 model that came with full piano black one, so I would say yes...X3 and X4 consoles are same shape. Just the X4 has a leather part where the X3 has a soft plastic one. Actually X3M has it in leather too.
dinan5m34370.00 |
06-01-2022, 10:16 AM | #20 | |
Rep 2,115
Goal here is to once i have the part, see closer whether the two side leather pieces could actually get removed, and installed without making things worse. Otherwise the whole thing will need to get replaced. Rationale i'm using is, F97 and G02 share common parts. I see in another thread this G01 (if it is really a G01) in seoul took F97 parts including center console. Hence G02 ought to be direct replacement G01. Again will see. I was more worried looking through TIS last night, there were more stuffs i may need to disconnect such as usb hub, air bag controllers, etc. but looks like they maybe mounted on the carpet floor, and not attached to the center console itself. Can't be sure but looks that way. If this swap can be done even if as a whole replacement, the outcome would be worth it, i think. |
06-01-2022, 11:08 AM | #21 |
Rep 912
Apologies, it wasn’t my intention to come across as stroppy.
I’m very relaxed
freshxdough3552.00 |
06-01-2022, 12:42 PM | #22 | |
Rep 2,115
