10-16-2011, 09:35 AM | #1 |
Rep 46
Understanding Profiles in 2012 X3
Trying to figure out how "profiles" works with 2 sets of keys (husband and wife) with different settings for seats/mirrors/pre sets, etc. Here are my questions:
1. I'm driving and I make a minor seat or mirror adjustment. Is that automatically saved to my profile (my profile is engaged already as I'm driving). Or do I have to do something to save it to my profile? 2. In my 2011 328i (with convenience/comfort access), the car senses who opens the drivers door (with whose key in the pocket) -- without any unlocking -- and adjusts accordingly (seat moves, mirrors move, etc); radio settings for driver are changes -- as soon as door is opened (no unlocking rquired). With the 2012 X3 (also with convenience access/comfort access), do you have to hit the unlock button on the remote or manually choose a profile in idrive to change it to the next driver who gets in? Or does it auto sense it (based on the key in pocket) like in my 328i? I've tested this, but it does't seem to work in the x3. In other words, do you have to do anything manually so that the car moves seat, mirrors and other settings for new driver (when car is already unlocked)? Assume idrive is set with settings to auto move seats, etc. for each driver. By the way, all of the above assume the car is not locked. When we park in our garage at home, we don't lock. 3. I'm driving with my profile and pull up to valet or service person. Do I set the profile to "guest" with engine running? If the valet later locks the car and opens with my key (assume I do not give valet key), doesn't it revert back to my profile? How does it stay at guest profile, so valet doesn't mess up my profile (if valet moves seat and stuff)? Is there some other better way to handle this valet situation? |
10-16-2011, 09:48 AM | #2 |
Rep 350
According to onboard manual profiles do not remember mirror settings... at least that is what I read from my test drive X3.
Sorry not to answer your question... |
10-16-2011, 10:40 AM | #3 | |
Live for today tomorrow never comes
1989
Rep 9,498
I think you have to select the memory setting ( 1 or 2 ) in the door panel once everything has been set , at least thats what I remember doing ( Could be wrong though).
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
10-16-2011, 11:17 AM | #4 |
Rep 46
I have all of the necessary options. Tech, premium, convenience packages.
10-17-2011, 03:34 PM | #5 | |||
Rep 3,855
Hope this helps
10-17-2011, 09:13 PM | #6 | |
Rep 46
10-18-2011, 01:02 AM | #7 |
Rep 3,855
It isn't that difficult to spend 10 minutes in the car with both key fobs working it out for yourself. Perhaps when you do you this you can enlighten us and correct the ton of misinformation rather than just dismissing it. I did this 8 months ago, understand exactly how it works (except for the guest profile which, as I said, I have never used) and I haven't had any problems since
10-18-2011, 06:29 AM | #8 | |
Rep 46
For example, with comfort access, even with the car already unlocked, the car recognizes the key when you open the driver's door (the key on the person who opens the driver's door) - and loads the profile associated with that key. So no need to unlock. Weirdly, the manual makes no mention of this. |
10-18-2011, 07:11 AM | #9 |
Rep 3,855
If you take "unlock" to mean "press unlock on key fob" or "touch door handle with key in pocket", the rest of the process surely remains the same and should be independent of how you "unlock". The car doesn't have to be locked to "unlock" it
10-24-2011, 03:06 PM | #10 |
Rep 3,855
Did you work this out? Other members may be interested
10-24-2011, 03:30 PM | #11 |
Rep 12,276
I think there are two types of profile automation: There is how it is supposed to work, and then there is how it sometimes works... both our X5 and X3 have CA, and there can be some bizzzare and annoyoing idiosyncracies. First, it is important to understand that you have a choice of when the profile is read and adjustments are made: 1) Upon unlocking, 2) Upon vehicle start. You select this in the vehicle settings in iDrive.
Because the system is using a radio signal between the fob and the system, it can be challenging when both driver and passenger have their key with them. But even so, it is usually able to determine who is in the driver's seat. The profile should: Set the seat position, set the sideview mirror positions, set the radio presets, set the climate preferences and settings, DRL setting, auto-lock settings, last iDrive screen displayed, last entertainment source, alarm beep/no beep, triple turn signal preference, and some others like whether you take cream and sugar. It is still highly advisable to set the long-term seat memory (1,2) for each driver just in case it does not auto-adjust. Also, every time they do a software update on your car it blows most or all of the profile settings away. It's like taking delivery of your new car all over again... over and over....
I think it is bad luck to be superstitious |
10-24-2011, 03:57 PM | #12 |
Rep 4,848
I will try it when both fob presents, what happens if the passengers side gets unlocked. When I was testing it on the weekend, it selects the profile that unlocks the car.
Macan S Diesel - Carrera White
Macan Turbo - White 1///M - Valencia Orange |
10-24-2011, 04:05 PM | #13 | |
Rep 4,848
2. Will try that later and report. Just a note though if you got comfort access, just make sure you lock your car if you are going to be away for a while as it drains the battery. Numerous report from people leaving their cars unlocked and went away and they can't start their car after only two weeks. It is not X3 specific so they might have fixed that. 3. I think the most convenient way is to have your seat position memorised. Just press 1 and 2 once you get back in the car. The seats will go back to the position last lock. Remember in a valet situation you usually have your car driven to you, so the car is already running and you wouldn't turn off the car, and restart again. Also, the memory seats 1 and 2 is attached to the fob as well. So, you can have two positions for each key.
10-24-2011, 04:38 PM | #14 |
Rep 3,855
This isn't true strictly speaking. What is saved is the last position the seat and mirrors were in when you lock the car. As soon as you change the seat or mirror again these settings are overwritten. To permanently save them to your profile you need to use M + 1 or M + 2.
Aside the from the method of unlocking (and consequently switching profile) the profiles seem to work exactly the same way as without CA (as I expected) and therefore my description of what gets saved, when and how is accurate with or without CA
10-24-2011, 06:00 PM | #15 | |
Rep 4,848
10-24-2011, 11:46 PM | #16 | |
Rep 4,848
10-25-2011, 04:50 AM | #17 |
Rep 4,848
Okay, I worked it out. If you "unlock" your car on the driver's side it will change over. As soon as you put your hand through the handle it unlocks (even if it is already unlocked). Didn't work for my wife this morning probably because she didn't unlock the car for some how the way she opens the door.
10-25-2011, 05:11 AM | #18 | |
Rep 3,855
10-25-2011, 02:12 PM | #19 |
Getting there...
Rep 33
I must be missing something. I have CA and profiles set on the iDRIVE as well. Lets say my wife was the last to drive the car. When I approach the car the next day, touch the handle to unlock, my seat position doesnt move. I would have to go into my "profile" on the idrive, select that, then I press 1 to get my seat position. What am i missing here? is there a simpler way?
10-25-2011, 02:49 PM | #20 | |
Rep 3,855
10-25-2011, 06:52 PM | #21 | |
Rep 64
Like others who have participated in this thread, my wife and I have been struggling with this as well. She is much shorter than I am; so, of course, she needs different seat and mirror settings than me. Our objective is to have the driver's seat and the outside rear-view mirrors automatically set correctly for the person who is about to start driving the X3. When everything is set up as I describe below, the individual settings for a driver will go into effect when the unlock button is pressed on that person's (key) remote. First, as others have indicated, the functioning of the seat memory buttons "[M] [1] and [2]" is completely independent of what BMW calls "personal profiles". Here I will only talk about how the "profiles" feature appears to behave in our 2012 X3 28i. (Note: You can set up three different personal profiles. There is also a "Guest" profile that I do not discuss here.) After considerable experimentation, I concluded that various different answers in this thread each have pieces of the correct answer; but those pieces are context-dependent - hence the apparent contradictions in some of the replies. These context dependencies can be a bit tricky. There's certainly more to it than first met my eye. In my opinion the Owner's Manual is very incomplete and confusing; so let me take a stab at explaining how I think this system works. First I'll explain how I set up two driver profiles, one for myself ("Jack"), and one for my wife, "Dee". In order for all of this to work, you must first associate each physical key (remote) with a separate profile. Step 1. I took my key (making sure that Dee's key was not also in the car), got into the X3, and started it up. Step 2. Using the iDrive, I selected "Settings", then "Door locks", and made sure that the "Last seat position is automatic" item was checked. Step 3. Using the iDrive, I selected "Settings", then "Profiles". On the right-hand side I saw a list of three profiles each currently named "(-----)", followed by a profile named "Guest". You will see a check mark next to one of the "(-----)" profiles - that is the "current profile", i.e., the one that is presently "active" in the vehicle and that is associated with the key presently located inside the vehicle (in this example mine). Step 4. I made sure the current profile (the checked one) was highlighed, then pressed the "Option" button. Then I selected "Rename current profile", and entered "Jack", then selected [Ok]. Step 5. I put the seat and mirrors in my preferred positions, and turned the engine off; then I got out of the car and used my remote to lock it. (I realize many other things are saved with each profile, but I'm only concerned with the seats and exterior mirrors here.) Note: Each time you lock the car, the states of the various settings, as they exist at that moment, are re-saved in the current profile (the one that is associated with the remote key in use.) Step 6. I took my key into the house, left it there, brought Dee's key out to the car, and started the engine. Step 7. Using the iDrive, I selected "Settings", then "Door locks", and made sure that the "Last seat position is automatic" item was checked. (Note: This setting, alomg with others, is saved with each profile, so you need to do this for each profile.) Step 8. Using the iDrive, I selected "Settings", then "Profiles". On the right-hand side I made sure that the current profile (the one with the check mark by it) was one of the two remaining profiles still named "(-----)". Step 9. I made sure the current profile was highlighed, then pressed the "Option" button. Then I selected "Rename current profile", and entered "Dee", then selected [Ok]. Step 10. With the engine still running, I had my wife sit in the car, and she put the seat and mirrors in her preferred positions. She then turned the engine off, got out of the car, and used her remote to lock it. This saved the X3's present state settings into her profile. That's it - everything is now set up. Our 2012 X3 does not have comfort access; and, at least without CA, you must start the change-to-a-different-driver process with the car actually locked, in order for the unlock button on the new driver's remote to invoke that new driver's profile. So from now on (at least on cars without CA), if you want to maintain marital bliss, make sure that each driver locks the car each time after driving it - even if it's parked in a locked garage. I hope others will add clarifications and make any necesary corrections to my explanations. Jack. |
10-25-2011, 08:45 PM | #22 | |
Rep 67
The way I somewhat fixed it, was make sure each profile had the "load profile menu on startup" (or whatever it's called), it's a wee bit annoying at first, but we got used to it, it's just an extra push of the iDrive knob (I don't like waiting for the "Accept" crap from the splash screen to go away on its own...) But, this still leaves the scenario when we drop each other off and the driver swaps around, it would mean we'd have to each get out of the car, whoever was driving turn off car & lock doors, only for the other driver to unlock & start car again, or profiles still get weird sometimes because my key remembers her last preset as my own. Profile management has to be the biggest "headache" we've had with the X3, but at least the seat memory buttons are never wrong, so it's a big old 5 second thing to fix it. Sad that nearly all my other cars did this with so much ease & never, ever got mixed up... |
