04-12-2020, 02:24 PM | #1 |
Rep 28
continuous coolant loss - no signs
Hey guys.
Yes I have searched, extensively... I have a 2015 x3 28i, 60,000 miles on the clock. It is losing far more coolant than it should. I have owned it for 3 years. It started slow but is getting worse. Now the warning comes on and I add about 1 to 2 cups of fluid every 2000 ish miles. Nearly all my driving is city, and it never gets hot (it has been below freezing for the last 6 months up here), but I do have a heated garage that it is parked in every night. I have looked everywhere I can think in the engine bay, with a flashlight and mirror in hand (I washed out the engine bay really well a couple months ago to help find it after a fruitless search at that time as well) No sign of leaks anywhere. The bottom of the expansion tank is spotless, same with every fitting I can get to. No marks on the garage floor.... I just changed the oil and no milkyness there. Exhaust is normal, no sweet smell or excess white "smoke". I'm stumped. Do I just start swapping parts?? I know the expansion tank is the usual culprit, and that is where I will likely start, but there are no signs of a leak at all. That much fluid loss should show, shouldn't it?? Thoughts? Thanks in advance. James |
04-12-2020, 03:07 PM | #2 | |
Rep 4,337
04-12-2020, 03:16 PM | #3 |
Rep 1,906
Get the cooling system checked with a pressurized leak tester. Shop can do or you can buy one and DIY...better route than swapping parts at random.
tracer bullet2417.50 |
04-12-2020, 06:18 PM | #4 | |
Rep 28
It is always parked in the same place in the garage, nothing on the floor. Granted I haven't removed the belly pan and left it off, so maybe it is collecting there and then evaporating. Once the roads are dry up here I may do that (probably another 2 to 3 weeks before the snow is gone). Thanks! |
04-12-2020, 06:20 PM | #5 | |
Rep 28
Maybe pressure it up and leave it pressured for an hour to see if it leaks.... Hmmm have to look into those. One of few tools I don't already own. Thanks for the reply |
04-12-2020, 06:28 PM | #6 | |
Rep 4,337
04-12-2020, 06:58 PM | #7 | |
Rep 1,906
note the comment about the expansion tank cap. |
04-13-2020, 06:06 AM | #9 |
Rep 9
I had the same issue last year. Mine is a 2011 X3 35i. The floor and engine bay was clean as the coolant leaked only while driving/engine was running. The culprit was a fine hairline crack in the water pump. This was detected while doing multi point inspection during an oil change service.
04-13-2020, 07:36 AM | #10 | |
Rep 4,337
How many miles were on your X3 when you noticed the water pump crack? |
04-13-2020, 08:35 AM | #11 |
Rep 9
About 95000 Kilometers, just under 60K miles. $1500 to replace it by the dealer.
Marty in NY2723.00 |
04-13-2020, 08:39 AM | #12 | |
Rep 1,906
I believe BMW has somewhat recently moved back to using mechanical pumps on newer motors. |
04-13-2020, 11:47 AM | #13 |
Rep 1,044
The inside of the belly pan is smooth. There is a drain hole about 1/2 way back. Take the pan off and drive around until the car gets warm. Put the car up on jackstands and start the motor. The waterpump and thermostat are hidden in a cubbyhole and there are numerous hoses and connections where seepage can occur. I replaced mine last year. It was a bear of a job.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
04-13-2020, 01:49 PM | #14 | |
Rep 4,337
https://www.youtube.com/watch?v=o-BpUzAemyQ |
04-13-2020, 02:07 PM | #15 |
Rep 2,547
Use a UV light (black light) in the dark to look for a leak anywhere there's coolant flow (hoses/water pump/radiator/etc...)
04-13-2020, 05:31 PM | #16 |
Rep 253
I had the problem on my diesel 2015 for a few years. Had to add a little coolant every few months. (I tried not to wait until the warning). Dealers acted like it was normal. In my case, it seems to have stopped when I had my EGR recall done. It apparently was leaking and burning coolant.
But you have the gas engine. I can understand your frustration. The worry that maybe it will suddenly get worse on a road trip. |
04-13-2020, 08:24 PM | #17 | ||
Rep 1,906
04-14-2020, 08:53 AM | #18 |
Rep 28
thanks everyone. Some good ideas and tips here. Never thought of the black light... that's a good one.
You guys are probably right, water pump is a good bet. Hopefully I can get under there this weekend and have a closer look. |
04-14-2020, 09:05 AM | #19 |
Rep 28
Anyone know how different the 6cyl is from the 4 for the water pump? most of the guides (like the Bavarian one posted here) are for a 6cyl or they don't specify.
04-14-2020, 09:13 AM | #20 |
Rep 80
Check the level sensor under the expansion tank as its prone to leaking there. Mine did. Also check around the cap for any dried up coolant as the cap could be passing steam. Do you smell coolant after you park it? Sort of a sweet, slightly burnt smell. I believe you need to add a die to the coolant for the black light to work. If you remove the under pan and run the engine until the pump is running, turn off engine, then you should be able to reach up around the water pump and thermostat on passenger side to feel any weeping/wetness and if there is, smell it for coolant. Careful as it can be hot! While you are under the car, check all coolant hoses and pipes, joints, for leakage.
04-14-2020, 09:31 AM | #21 |
Rep 80
The 4cyl and 6 cyl water pumps are different. the 4cyl pump I believe has a metal head while the 6 cyl has a black plastic head (where you connect the hoses. Carefull of Chinese knock off pumps on ebay and Amazon. VDO/Continental are reliable and make the OEM pump. Also it is super highly recommended to replace the thermostat at the same time.
04-14-2020, 10:13 AM | #22 | |
Rep 4,337
It appears though that on either model X3, the water pump and T-stat are in the same location, that is the passenger side of the engine at the bottom, all access is via the bottom of the car. So, you get to lay down and be comfortable when changing them out while of course getting coolant dripping on your face, in your eyes, nose and mouth :-) Its either a PITA to do yourself, not impossible by any means, but just a pain or expensive to have a shop do it. If you end up replacing your water pump, be sure to also replace the T-stat too. Hopefully for you, its just a hose leakage instead. . |
