      11-25-2015, 03:25 PM   #1
X3BMW
Drives: 2013 white/black X3
adaptive headlight malfunction
Just got warning light adaptive headlight malfunction and warning light low beam malfunction. One of the daylight running lights is out, not the outer rim light the actual light. Is that a bulb to replace or a bigger deal?
      11-25-2015, 03:37 PM   #2
ejw2011
ejw2011's Avatar
94
Drives: x3 F25 35i, x1 F48 28i
It could be the xenon bulb or the ballast. Easy thing to do is swap the good bulb to the bad side to test. If it doesn't light then try swapping the ballast.
      11-25-2015, 07:31 PM   #3
///Mposter
Macgyver
///Mposter's Avatar
Drives: 2007 e92 335i
Hey mine did the same. It was the module and not the bulb. The order was adaptive headlight malfunction then after startup for the 2nd time it was headlight bulb .
Dealer swapped bulb and did not work.
The drivers side on mine was replaced.
63-11-7-356-250 control unit xenon $517
labor $ 416 for 3.20 hours
You can did them used for $50-$100 and I think if you took off the splash guard , you could replace without taking the bumper off.
