      02-02-2013, 12:54 PM   #1
WPG D33Z
Drives: 2008 135i vert Cobb Stage2
X3 wont start, its pretty cold out - Turns over slowly sputters and dies
My X3 hasn't been able to start for two days now in pretty frigid weather (-35c). At first I thought it was the battery so I left the charger on over night and it still wouldn't start. I then went and bought another battery put it in and have the same problem.
When I try to start the car it is very slow to turn over, it makes a sputtering sound and almost starts but then dies. I popped the hood and noticed that fresh oil is leaking from the part in the picture, I'm wondering if that is the problem?
Name:  x3 oil leak.jpg
2008 SGM 135i Cobb Stage 2 FBO
2008 TS X3 MSport KW V2
      02-02-2013, 05:19 PM   #2
romanonj
romanonj's Avatar
145
Drives: F80 DCT
It is your oil filter, whenever oil is leaking it should be addresses, so def a problem. I can't tell from the pic where it is coming from, but either filter or oil cooler gasket popped.. -35 man that's cold..
2016 F80 M3 BSM with Black interior DCT/Driver Assistance/Executive/LEDs/Adaptive/Black Wheels
2014 F32 435i xDrive AW/CR
2014 F25 X3 M-Sport Carbon Black
2011 e92 335is 2007 X3 122k miles 2006 e90 330i 132k miles
      02-04-2013, 06:25 PM   #3
WPG D33Z
Turns out I flooded the engine and fouled my plugs, they were black. Changed the plugs and oil and its all good. Decided to install an oil pan heater while at it.
      02-06-2013, 10:17 AM   #4
R1000K3
R1000K3's Avatar
Drives: 335i MT
A common problem is when cars have been sitting a couple of days in very low temperature. Water in the tank or fuel filter will then freeze and block the fuel supply so the engine may start but not run.
      02-16-2013, 09:50 AM   #5
Paralytic
Drives: BMW X3 2.5si
maybe it froze some of your fluid hoses?
      03-04-2013, 10:04 AM   #6
WPGX3
Drives: 2009 X3 M Sport
How much did oil pan heater install cost you? It was real cold there for a short while, couple rough early morning starts definitely. I feel your pain
      03-04-2013, 12:17 PM   #7
WPG D33Z
I paid $125 installed, going to put one on my 135i as well for next winter. X3 starts great with it!
      03-05-2013, 12:54 AM   #8
WPGX3
Where did you go for install ?
      03-05-2013, 07:56 AM   #9
WPG D33Z
I've got an indy mechanic that works on my bimmers, I could ask him if he would do yours if you like.
      03-06-2013, 11:31 PM   #10
WPGX3
I'd definitely be interested. Thanks
      02-15-2015, 09:22 PM   #11
Mingstar88
Drives: BMW X3 35i
think my car is having same problem right now. please assist
http://x3.xbimmers.com/forums/showthread.php?t=1091753
how much for plugs and oil? i have an indy mechanic, not sure if he has the stuff
edit: would this be covered under warranty?
