      11-04-2020, 03:52 PM   #1
evilchargerfan
evilchargerfan's Avatar
Drives: 2012 F25 (N55), 2014 I01 (REX)
Thumbs up DIY: Let's Replace Our Interior Door Pull Handle, Front Right
Okay we're back again for another DIY!
Interior Door Pull Handle (front/passenger side) getting sticky? I got us covered fam!
I believe the PN is 51419209216. Some places name the part "Support, pull strap, right", some places name it "Interior Door Pull Handle, Front Right"
Affordable replacement found on amazon/ebay
Here are the steps I performed:
Our sticky culprit
Pry off speaker grille
Remove screw behind
Pry leather cover
Remove 2 screws behind the leather cover
Remove 2 screws at the bottom of door panel
Pry door panel from all sides, go slow and "Feel" for what needs to be pry'd
These are the little clips you're prying
Slide door lock out of its hole
* * * to be continued * * *
      11-04-2020, 03:54 PM   #2
evilchargerfan
The back of door panel should look like this
The handle is held on by 2 screws, remove them both
I used a flat head to push in the tabs, then pushed away from me to release it
At this point, you can pull it out
Side by side comparo
Install in reverse order, simple enough
PROFIT
Wgosma806.00
      10-31-2021, 02:48 PM   #3
OldenburgerM3
OldenburgerM3's Avatar
72
Drives: 2011 Jet Black M3 Coupe
Oh my goodness this is excellent! I have that problem on the driver-side, this gives me hope to find the part.
Edit: Found it: https://x3.xbimmers.com/forums/showt...de+door+handle
      11-03-2021, 04:19 PM   #4
evilchargerfan
drivers side was probably 10x easier to do
best of luck!
