      08-18-2014, 02:44 PM   #1
cwaturner
14 X3 xDrive 28i; 16 RX350 F-Sport AWD
Drives: 2017 X3 28i M-Sport
Dot in electronic display
Sometimes I get a dot in the display of the range remaining gauge. Has anyone else ever seen this? Does anyone know what it means?
      08-18-2014, 07:56 PM   #2
v1kt0rm1ke
Drives: 2014 X3 F25
Hi - if you're referring to the green dot, in my AU version dial looks a bit different but that's the speed set for cruise control. Goes red (but stays there) when cruise control is disengaged until you set it at a different speed
Hope this helps
      08-19-2014, 11:46 AM   #3
cwaturner
Thanks, I am actually referring to the white dot under the speed display, right at the Zero of the Miles Remaining display. Sometimes this is a white dot, sometimes it is a white line.
      08-19-2014, 01:36 PM   #4
lovec1990
Drives: X
that dot shows if you have enough fuel to reach your destination
      08-19-2014, 01:39 PM   #5
cwaturner
Interesting, thanks!
