      08-27-2014, 04:02 PM   #1
Sarsippius3rd
Sarsippius3rd's Avatar
13
Drives: 2015 BMW X4 28i
X4 310 with pirelli pzeroes and winter
Anyone know the potential drivability of these wheels/tires in the winter and snow? Got the car without realizing it was performance tires and not all seasons.
      08-27-2014, 09:00 PM   #2
plutnicki
Drives: 2024 M8C Coupe & 2019 X3 M40i
Zero
Zero, nil, nada.
Wouldn't go anywhere near winter in New England (I'm in NH) with a "performance tire". Most people will tell you that even all-seasons are marginal.
Probably not what you wanted to hear, but if it were me, I'd get a winter tire/wheel package. Good news is that you'll have the best of both worlds, and the performance tires will last longer.
      08-27-2014, 09:08 PM   #3
Roundown
Originally Posted by plutnicki View Post
Zero, nil, nada.
This is 100% right. You'd be a danger to yourself and others on those tires in temperatures below 40 degrees and/or traveling through any type of frozen precipitation.
You can get a good set of 19" wheels with Pirelli Sottozero II RFTs from tire rack for ~$2500. Or you could go for the BMW 18" set for ~$2700. A lot of folks scoff at the expense, but you'll be reducing the amount of wear you put on a $500 tire (your 20" P-Zero) and sparring your aluminum 20" rim winter pot holes.
I went with the staggered 19" with P-Zeros (like yours) on my '15 X3 and just ordered my winter set up!
Good luck.
      08-27-2014, 10:52 PM   #4
Sarsippius3rd
13
Thanks for the replies. Was pretty sure that was the answer.
      08-30-2014, 01:48 AM   #5
Tjalle
Drives: X4 35i
I am curious- what type of tests for winter tires do you have in the US - we have extensive tests in Sweden, Germany and Finland.
Last winter BIC for non-studded tires were: Nokian Hakkapelitta R2 and Michelin Alpin.
BIC for studded tires were: Continental Conti Contact and Pirelli Ice Zero.
I will buy 18" Pirelli Ice Zero (or whatever tire is BIC coming season) without TPMS (Tire pressure monitoring system) and with AEZ Yacht rims.
Note: there is a new TPMS on X3/X4 for this year with pressure sensors installed on the valves instead of utilizing signals from the ABS system.
