      09-18-2023, 12:13 PM   #1
x3Prancer
Drives: 2019 X3 sDrive30i
Emergency call system malfunction Bimmer Coding or TCU replacment
Hi All, I have a 2019 X3 sDrive, and I am getting the "Emergency call system malfunction" error showing up in my instrument cluster. My car has 54K miles, 4K over the warranty expiration.
I bought BimmerLink, BimmerCode and OBDLink CX. The errors showing up in Bimmer Link is:
"Error Accessing SIMM Card" (see pic).
Researching this a bit, I tried replacing the battery, error came back next day after clearing.
There is no evidence of water leakage. (se pic below)
I tried to remove the TCU under the antenna to inspect it, but wasn't able to get the plugs to come off the TCU. Didn't want to break the wires, but looking at it under the roof disconnected from the antenna, I didnt see any water damage there either.
So I went on to my next option, which was trying to code the error off my instrument/display panels.
Again, after some online research, I found de-activating the following might turn off the error message on my displays:
INSTRUMENT CLUSTER ->
3004 ERM_KONFIGURATION ->
ST_ECAL_TIMEOUT -==>> nicht_aktiv
ST_ECAL_ALIVE ==>> nicht_aktiv
I tried that, but the next day, the errors came back on my displays.
So, Im looking for some advice here on what I should do next.
1. TCU - I can't pull the plugs out to examine it. If I am able to get the wires off, should I try replacing it? Or, is there a SIMM in there I can re-seat? If I replace the whole unit, do I need to call BMW to get the SIMM registered?
2. Code the error off: I really dont care about the emergency call system, I always have my phone with me, and this feature is not guaranteed to last the lifetime of the car anyway. I would rather just get rid of the message and live without the emergency call system, as long as my satellite and GPS are working, that's all I need. Does anyone know how I can code off these messages.
If anyone had this issue, and was able to fix it themselves, I would appreciate hearing how you did it.
Thanks
      09-20-2023, 02:34 PM   #2
x3Prancer
Solved! I was able to suppress the error message using Bimmer Code. I tried the following Bimmer Code changes, the first one didnt work, the second one did. I haven't seen the emergency call system malfunction on my dash anymore.
1. INSTRUMENT CLUSTER (expert mode)
ST_ECAL_TIMEOUT
ST_ECAL_ALIVE
2. Instrument Cluster (Expert Mode)
300A CC_Konfiguration
CC_MELDUNG_0299=> nicht_aktiv
Nothing else has been affected AFAIK, only needed to set the system date/time.
The "No Access to Internal SIM Card" is still present in Bimmer Link.
But not showing up on the dash anymore.
sp20007.50
      11-22-2023, 09:25 PM   #3
Jc02988
Drives: G01 M40i
Has the Call system malfunction light came back after coding? Looking to do this to mine as I have the same issue and wanted to know if the warring is stil suppressed.
      11-24-2023, 03:53 PM   #4
MdW86
Drives: Bmw f30 320i 2012
Why code off a feature that could save your life?
The battery can easily be replaced. There is an topic with pics how me and other did it. Job takes about 1 hour if you’re a real amateur like me.
      12-02-2023, 09:53 AM   #5
Jc02988
Drives: G01 M40i
I have changed the battery, no luck, that was not what was wrong with mine. Took it to the dealer and they wanted 3k to replace the TCU. I don’t mind paying for repairs but I do not want to pay 3k for feature that has no purpose to the drivability or performance of the vehicle.
I’d much rather clear the warring that will not leave the dash no matter what you do. Why block the odometer with this warning!?
      12-02-2023, 04:16 PM   #6
AlteBMW
AlteBMW's Avatar
Drives: '23 760ix; '23 X3; '23 MB wgn
$3000 sounds ridiculous and at that price I wouldn't fix it either. But what do the parts sites say about the cost of a new TCU? If reasonable you could try it on your own or have an indy do it. That assumes it is not a humungous job.
BMWCCA
Current: 23 760ix (Carbon Black/Tartufo) (after first one totaled) '23 X3; '23 MB E Wagon
Prior: BMWs (3,5,7 & 8 series (2x!)) X3, MB (C, E, and S), Alfa GTV, MGB, Audi (A4, A6), Saab, Volvo, Toyota, Lincoln, Chrysler, Oldsmobile, Chevy, Rambler.
      12-09-2023, 05:45 PM   #7
Jc02988
Drives: G01 M40i
Can confirm that using BimmerCode you can code away the “emergency call system malfunction” warning on the dash.
Did it today and the warning is gone and seems like everything else is working just fine.
G01 2018 X3 M40i
jsh1391698.00
MrColl0.00
      12-28-2023, 04:19 PM   #8
RockChalkKU
Chump
RockChalkKU's Avatar
Drives: '16 LBB M2/'18 X3 M40i/'16 X5d
Worked for me as well. Thanks for posting this!
Past
2010 335d DUDMD Stage 2
2000 LMB M5
2010 BSM M5
2007 BSM 6mt M5
      03-27-2024, 10:22 PM   #9
MrColl
Drives: BMW X3
Any of you guys experiencing problems with the Mic not working? I was about to code mine too but now one of the mics is not working.
      04-25-2024, 10:50 PM   #10
RKSaint
Drives: 2019 BMW X3 Sdrive30i
Yeah your mic will not work. I guess it's connected to the TCU unit and without it will not work.
