      05-14-2022, 08:34 AM   #1
Dandle
Drives: G05 X5 M50i
Panaramic sunroof seal replacement.
Just thought I would share that I have replaced the rear seal on the opener of the panoramic sunroof today. It had shrunk over time and this left an 8-10mm open gap each side of the panel.
It's really easy to change and isn't bonded on, the profile of the rubber just fits into the plastic molding of the glass panel, it took about 10 minutes to change with a set or steps to get up there.
Part no. Of the rubber is 54107493155 and it's slightly over sized so you just have to trim it down.
I didn't take any pics before but have a couple of it fitted.
      05-14-2022, 12:17 PM   #2
Goldiegee
England
154
Drives: X3 M40i LCI
I have seen other posts where this was cited as a source of wind noise. BMW will replace under warranty if the car is still covered
      05-14-2022, 01:49 PM   #3
spangle1980
Deadly
1315
Drives: X3 M40d BG LCI
Funny that - mine had shrunk by the same amount. Dealer ordered and installed new one a couple of months back. Seemed to lessen some whistling noise I was getting from omni-direction :-)
330DW33.00
      05-14-2022, 03:17 PM   #4
kevinkay
kevinkay's Avatar
Drives: X3
got me curious, and ran out to check my car.
Did'nt understand and looked fine on the drivers side, then checked out the passenger side, wow- Here is your "BEFORE".....
Thanks for posting this!
(#5 in diagram)
dfc888108.00
Plusforce156.00
      05-14-2022, 06:31 PM   #5
Goldiegee
England
154
Drives: X3 M40i LCI
The thread that covers it is called
Wind noise / whistle on 2022 X3 M40i
Can't seem to link it on my phone sorry.
      05-14-2022, 06:56 PM   #6
Dandle
Drives: G05 X5 M50i
Mine didn't give me any wind noise or whistle but I was concerned about the extra water ingress when it rained or the car was washed.
The gaps on mine were similar if not slightly bigger than the ones on kevinkays car.
The thread might be useful to a few people.
      05-15-2022, 09:58 PM   #7
dinan5m3
dinan5m3's Avatar
4264
Drives: e39 m5 e46 m3 g01 x3m40i
https://static.nhtsa.gov/odi/tsbs/20...06684-9999.pdf
kevinkay271.50
      05-16-2022, 02:45 AM   #8
Dandle
Drives: G05 X5 M50i
Originally Posted by dinan5m3 View Post
Thats a great document.
On a side not any know where the rear drains exit? I'm Guessing its behind the bumper looking at the doc.
      05-16-2022, 10:24 AM   #9
dinan5m3
dinan5m3's Avatar
4264
Appointment made.
For DIYer's:
      05-17-2022, 01:48 AM   #10
spangle1980
Deadly
1315
Indeed a great document. I love it when a company has rigid process. This caught my eye:
An extra screw may have
fallen into the track during production. The screw is not
missing from any location.
-- So they have enough "loose screws" on production that it makes it into an advisory :-|
      05-17-2022, 04:30 PM   #11
dinan5m3
dinan5m3's Avatar
4264
From SA:
Replying back to confirm that it's a feature:
SA reply:
kevinkay271.50
      05-17-2022, 04:55 PM   #12
kevinkay
kevinkay's Avatar
Drives: X3
My plan is to drive in, show my SA and if any question arises - lets walk over to the showroom or new car lot and compare rubber.
From SA:
SA reply:
dinan5m34263.50
      10-27-2022, 05:37 AM   #13
kevinkay
kevinkay's Avatar
Drives: X3
Just had mine replaced at the dealer - under warrantee.
Drove in and showed the service adviser the gap, she made me a service appointment. unfortunately they did not pre-order the part so took 2 days to get the new seal once the tech looked it over. I watched the tech put it on - took about 20 min and tech was using a mirror (like a dental mirror) and maybe a screwdriver. Looked like he was verifying it was properly attaching with the mirror.
509er589.50
dinan5m34263.50
      12-11-2022, 10:45 AM   #14
Ayyleoo
Drives: BMW X3 M40
It will do warranty under new car warranty.
      12-11-2022, 10:47 AM   #15
Ayyleoo
Drives: BMW X3 M40
Are you still under new car warranty ?
      02-27-2023, 01:54 PM   #16
JasonX3
JasonX3's Avatar
48
Drives: X3 M40i
hey All,, just replaced mine front seal but the rubber is not flush nowwhen i push it in than it is flush the sides no gap anymore or is it normal that the rubber is a bit above the glas panel?
thank you all greetz from rotterdam
      02-27-2023, 02:26 PM   #17
br438
Infinite Boulder Roller
584
Drives: 2020 Ford Raptor
mine was replaced under warranty at 7 months after picking it up from the factory.
      02-27-2023, 05:41 PM   #18
kevinkay
kevinkay's Avatar
Drives: X3
Mine was replaced under warrantee because I asked with the knowledge of this post - THANKS
I also asked it be "adjusted" as I thought the center of the movable glass was a bit higher in the center where it met with the back glass. The service adviser didn't really agree with me but the tech did. They tried to adjust but at max. adjustment they could not get it flush, determined the back glass was "defective" and so replaced the rear glass panel. Took a week, but I had a loner and always happy to get new parts!
      02-01-2024, 01:00 PM   #19
TheMooseInNam
Drives: X3 G01 xLine 2.0D
Thank you all
Huge thank you to all on this thread!!!
Picked up a 2018 X3 just before Christmas and the wind noise in the cabin was driving me mad in high winds or motorway driving.
Ordered the part mentioned above for €45 from main dealer (it’s now been superseded with part no. B54.10.5.B32.973).
Only took a few minutes to push/clip the new seal into place (with the help of a flat head screw driver). Did require about 5-7mm to be trimmed off. I made sure it was about 3-4mm too long to allow for some future shrinkage and squeezed it in.
Problem solved, cabin is lovely and quiet now
      02-01-2024, 08:21 PM   #20
Flippco
Flippco's Avatar
Drives: '23 X3 XM40i, Honda Passport
Thanks for reposting this! I just started to hear some noise from the sunroof, it’s worse driving into the wind. Even though it’s a MY23, I’m going to have it checked out at my next service appt.
bocabimmer1593.50
      02-02-2024, 05:57 AM   #21
bocabimmer
Found the Search Button
bocabimmer's Avatar
Drives: 2022 X3 30i xDrive
I’ve been through hurricanes that make less wind noise than my sunroof right now. It’s shrunk about a half inch so I scrunched it over to one side and have a piece of painters tape covering the hole. It’s working for now until my next service appointment but ugly as anything.
2022 X3 xDrive 30i M Sport, Brooklyn Grey / Cognac
Previous BMWs: 2018 330i (F30), 2014 i3 BEV, 2007 328i (E92), 2013 X5 35i (E70), 2014 i3 BEV, 2006 325i (E90)
Flippco1150.50
Resoelg244.00
      02-02-2024, 10:25 AM   #22
MyfirstBMW_X3M40i
MyfirstBMW_X3M40i's Avatar
149
Drives: BMW X3M40i LCI BG
Had mine checked during recent service, and it had shrunk a little both sides, MY2022, dealer ordered and replaced, picked up this morning and had a couple of hours drive. The cabin is quiet, but just had a little whistling now and again at motorway speeds which was the reason I had them check, can confirm nice and quiet again now.
