      03-22-2020, 07:37 PM   #1
pat_03
Drives: 2012 X3 35i
G01 Esys coding guidance
Hey folks,
I spent today doing a bunch of FDL coding on my 2019 X3 30i using Esys. There are a few things that are not working as expected and hoping to gain some insight.
- Digital Speedometer: I coded KI_DISP_CB_SPEED_DIGITAL to Aktiv, but there was no change. Still only get the large digital speedometer in Sport Mode only, which I believe is a stock setting. Is there another setting to code that will show digital speedometer in all driving modes, mainly comfort?
- Alpina style gauges: I coded ALPINA_ENABLE to Aktiv in Kombi2 but that did nothing
- Enhanced BT (EBT): I coded a large number of settings that I found across a few forums. I have Office (SMS etc...) working but cannot connect more than 1 phone still, and when streaming music, I cannot see the entire playlist, just select previous or next song
Screen Mirroring: I've got this working as tested with an LG phone, but I can't get my Essential Phone PH-1 to work. On the phone when I go to cast, I see the BMW but it just says connecting and times out. Does this just mean the phone itself is not compatible for some reason?
Email: Everything car wise should be enabled but I can't figure out how to set it up through Connected Drive portal. There is no option in my account to set up emails. Any direction here is appreciated.
Warnings: I coded everything out, but I did catch a warning when clicking reply on an SMS. How to code this out?
Seatbelt warning. How to code out the chime when driving without a seatbelt?
Could I have done anything to muck up the avg mileage in the instrument display? I went for a short drive today and it wouldn't move from 20L/100km, and drove real slow for a few mins to try and get it down and it never changed. I'll check again tomorrow and see, might have just been a blip
Thank you!
      03-23-2020, 06:27 AM   #2
titomi
titomi's Avatar
Drives: X3 G01 30i xDrive
2018 X3 G01  [0.00]
Originally Posted by pat_03 View Post
Hey folks,
Thank you!
Might be a good idea to check the bimmercode thread, there are some answers you are looking for. Although it's not for esys, you can find the values to code.
Afaik there is no way to show digital speedometer the way it is in sport modes in another modes. There is an option to show it in that part of instrument cluster, where the odometer, compass and others are shown.
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
      03-23-2020, 06:40 AM   #3
Douggie
Drives: BMW X1, X3
May I know what launcher are you using? I want to code, but seems no way to get the launcher now from Tokenmaster.
      03-23-2020, 10:09 AM   #4
pat_03
Drives: 2012 X3 35i
I'm using 2.8.2 it's the free premium version that is good until April sometime, you can get it right from his blog
      03-23-2020, 10:18 AM   #5
Douggie
Drives: BMW X1, X3
Oh. Mine is a 2020, so I can't read the trimmed CAFDs with 2.8.2... sigh. Thanks anyway.
      03-28-2020, 08:24 AM   #6
kevinwoods
Drives: 2019 BMW X3
I have launcher pro 2.8.2 pro from tokenmaster website downloaded free.
I tried to coded the digital speedo too. changed everything I could but no digital showed up in comfort or eco mode.
      03-28-2020, 08:59 AM   #7
teaston
Drives: X3 M40d
Is the digital speedo just the one you get if you cycle through the BC modes?
      03-28-2020, 09:08 AM   #8
teaston
Drives: X3 M40d
Hey folks,
Thank you!
Seatbelt warning is in ACSM module, think it’s called SeatBeltReminder_SBR_Fahrer for the drivers seat, or something like that.
      03-28-2020, 01:59 PM   #9
kevinwoods
Drives: 2019 BMW X3
not sure if I understand. I think the one you referred to is odometer, not speedometer? I was referring to the display of speed that you have in sport mode.
      03-28-2020, 02:07 PM   #10
teaston
Drives: X3 M40d
Yes, the coded digital speedo goes where the odometer is, when you cycle through the different BC modes it should be there afaik.
The digital speedo in the middle of the dials is only available in sport mode, as that is how the dials are designed.
You can code the sports dials to show when the car is in comfort mode though, so that could be your answer.
      03-29-2020, 07:58 AM   #11
kevinwoods
Drives: 2019 BMW X3
Thanks! I will give it a try again when I get a chance.
Do you have the code for selecting sport mode as default?
      03-29-2020, 09:10 AM   #12
teaston
Drives: X3 M40d
I don't know as I use bimmercode, sorry.
      03-30-2020, 07:40 AM   #13
victorngcm
Drives: F48
I successfully code my friend's X3. 2019 built 30i
1. album cover
2. engine start stop memory
however, I fail at
1. tipp 5 times turning signal (coded but np respond)
2. air conditioning memory (can't find the fdl location)
      03-30-2020, 08:30 AM   #14
teaston
Drives: X3 M40d
1. album cover
however, I fail at
Changing the one touch blinker doesn't work anymore.
      03-31-2020, 08:11 AM   #15
victorngcm
Drives: F48
1. album cover
however, I fail at
I drive x1. however I have the 5 time option in my I drive but my friend's x3 doesn't...
      03-31-2020, 08:31 AM   #16
teaston
Drives: X3 M40d
1. album cover
however, I fail at
X1 is built on the MINI platform, so has older hardware/software in it.
      03-31-2020, 05:59 PM   #17
ssurtie
Drives: bmw f25, g01, f30
hi, not sure if this is the right place to ask, but is there anyone able to direct me to where i can get the latest SpDaten and PsDzdata downloads?
      04-01-2020, 01:21 AM   #18
Douggie
Drives: BMW X1, X3
https://www.bimmerfest.com/forums/sh...d.php?t=983244
      04-04-2020, 03:52 PM   #19
kevinwoods
Drives: 2019 BMW X3
Does anyone have experience with the newer Launcher Pro from eBay?
There are some eBay sellers selling Launcher Pro 3.6.
https://www.ebay.co.uk/itm/223808037054
I used the Launcher Pro 2.8.2 from TM website. But it is kind outdated, and some functions for my 2019 G01 are trimmed.
      04-05-2020, 01:05 PM   #20
live
Drives: 2013 X3 x28i, 2018 X3 M40i
I made a $50+ donation per tokenmaster's(the software author) instructions and sent the proof to him but never get a replay. Anyone in the same boat?
I don't want to get a "pirate" version, but it seems I got stuck here.
      04-05-2020, 05:29 PM   #21
Douggie
Drives: BMW X1, X3
Yep, that's why I'm hesitant to go with tokenmaster. I might try the ebay version. I've messaged the seller a few times and the response is quick.
      04-06-2020, 12:42 AM   #22
6ixSpd
Save the manuals!
6ixSpd's Avatar
6015
Drives: '16 M3, '23 718 Spyder
I just purchased this one as my existing version is trimmed for G02. I'll post my experience with this seller once I have something to report back on.
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
Douggie142.00
kevinkay271.50
