07-08-2013, 10:38 AM | #1 |
Rep 59
Anyone put Morimoto HID kit for fog lamp?
Just want to know before I pulled the trigger for the HID conversion if there is any serious problem with it. Thanks!
07-09-2013, 05:56 AM | #3 |
Rep 233
I think these lights, low on the front bumper, are more accurately called driving lights. They are aimed low on the road and do not even come close to "blinding" or even distracting on coming drivers.
Driving Lights, if they put out a useful amount of light, do an excellent job of lighting up the road and shoulder surface directly in front of the car. I guess it can be argued that there is no need to see the area immediately in front of the car because anything seen is much too close to do anything about. Nevertheless, my preference is to see as much as possible. In my opinion the more properly aimed and distributed light in front of the car the better, and there is usually never enough. To that end I leave my driving lights on both my Z3 and Lexus set to be on any time the headlights are on. As soon as I get my hands on my X3 this week I plan to check out these lights. If they will do something consequentially more useful than the factory lights, are reliable, and not entail risk of damaging my car, I intend to buy and install them. |
07-09-2013, 11:13 AM | #4 | |
Rep 71
Thanks, dr |
07-09-2013, 01:03 PM | #5 | |
Rep 323
There are trucks scattered around the area that I live with HID kits stuffed into every orifice of the front bumper, and they absolutely blind other drivers. |
07-10-2013, 05:47 AM | #6 | |
Yorkshireman trapped in a Berkshire postcode
11
Rep 213
'Driving lights' are intended to supplement full(high) beam to give greater visibility when travelling at speed in the dark. Driving lights should be wired in such a way as to go off when switched to main(low) beam. Fog lights are for lighting up the road just in front of the car, helping to illuminate the kerbs and used in low speed, low visibility. Not intended for use (certainly according to the UK Highway Code) in visibility greater than 100m and in some cases the police are known to fine drivers for improper use. IMHO To put HID in a fog light housing is completely inappropriate - when used in fog the dazzle will negate the use of the lights. They're not driving lights or DRLs and they're not cool - improper use of fog lights makes you look like you don't know what you're doing with a car......
X3 3.0d M-Sport
Mini Countryman Cooper S ALL4 |
