05-26-2021, 03:14 PM | #1 |
Rep 48
Vibration/Humming when A/C on Maximum Fan Speed....What should I do?
Hi Everybody,
My car is making a vibration/humming noise which gets progressively louder as the a/c fan is turned up high. At low to med speeds, you don't hear it but only near or at max fan speed. The vibration can be felt on the center console. It is not mechanical like the fan is dying but rather more like a piece of debris is inside the vents and vibrating (think of blowing a blade of grass). How can I inspect or clean where there is possible debris causing this noise? From the outside or inside the car? Thanks in advance for your help for guidance on what to do next. Anthony |
05-26-2021, 03:53 PM | #2 | |
Rep 44
05-26-2021, 04:18 PM | #3 |
Rep 48
Problem solved. Removed passenger outside air filter and found this piece of debris/tape/insulation inside that must have been vibrating at high speeds. I will replace the air filter and call it a day.
Hope this helps somebody else. |
