      03-01-2012, 09:23 PM   #1
twerle
twerle's Avatar
35
Drives: 2016 M3 - MW / SO / Manual
Damn question, e46 wheels
Can I use the snow tires/rims from a 2005 e46 19" on the 2011-12-13 X3?
I know, what a stupid question! But non of my friends could answer me that question, so, here I'm.
      03-01-2012, 10:28 PM   #2
bren
user
bren's Avatar
Drives: German Camaro
You are missing quite a few details, but theoretically the wheels will fit although the tire diameter will be too small.
      03-02-2012, 06:00 AM   #3
02420X3
Drives: 2011 X3 35i
From a reply to another topic by Lotus7, here are the wheel specs for the F25:
FYI: Basic wheel specifications for the X3(F25) chassis are:
Bolt Circle = 5 X 120mm
Offset = 45mm (43 to 47mm acceptable)
Hub centering Bore = 72.5 mm (hub ring dia. = 72.47mm)
Bolts = M14X1.25 Conical seat, 17 mm heads (Note the X3(E83) uses M14X1.5 bolts)
Minimum bolt engagement = 9.5 turns
The bolt engagement spec is very important and is often overlooked. Some wheels have different hub thicknesses, so use different length lug bolts. If the replacement wheels are even slightly "thicker", you need longer bolts.
      03-02-2012, 02:39 PM   #4
Alligator69
Drives: X3 F25 2.0d Mineral Silver
I tried to find an answer to a similar question, if it was possible to fit my 17 rims, coming from my E91 to the new F25 to use them as winter tires.
The offset is 34 and perfectly fits, the real doubt was on the "robustness" of the rims (tires are different, of course), it seems rims come with a number similar to the "load index" of tires that should express the max load per wheel, that with an SUV vehicle should be higher than the one of a normal mid-size family car.
To be honest, I decided to take the risk and the result is (not bad uh?) in the picture below:
Like it?
      03-02-2012, 03:18 PM   #5
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
looks like a x5 with those rims.
Like it?
      03-02-2012, 05:30 PM   #6
twerle
twerle's Avatar
35
I like it!
Thank you for the quick reply.
When I get mine I will try, let see, if does not feet, well... too bad, since e46 rims can be installed on a e90 I see no reason why would not feet on the newer X3, I will make sure that a professional like townfair tires get it install just to be in the same side.
Your car looks really good BTW.
Like it?
      03-03-2012, 05:29 AM   #7
Alligator69
Thank you guys, winter is almost gone here in Italy and I will soon put back the 18' 308 style.
