      01-12-2020, 02:41 PM   #1
EndoDoc
Drives: X3 35i MSport
Oil dripping charge pipe
Size:  272.4 KBDoes anyone have an idea of where the oil pictured is coming from? I think that is the charge pipe on the driver side of the engine. I can trace it up to where it connects below the intake manifold but can't get a mirror and light in enough to see where it's coming from.
      01-13-2020, 07:22 AM   #2
TheCoolX3
Drives: 2016 BMW X3 35i M-Sport
Valve cover gasket or oil filter housing would be my best guesses
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others
Instagram @TheCoolX3
      01-13-2020, 07:38 PM   #3
EndoDoc
OFHG is good and valve cover appears good 360. Can this be blowby? I read in other N55 forums that blowby can force oil into the intake, to the throttle body and weeps out of the oring connection where the throttle body and charge pipe connect.
      01-13-2020, 10:37 PM   #4
TheCoolX3
Theoretically, yes it is possible. Unlikely though in your case. There would be a clear stream from the throttle body, which is not visible. In addition, if you had that much blow-by, there would be a much more significant issue to address here.
      01-14-2020, 09:53 AM   #5
Polo08816
Drives: 2014 335i M Sport
Yeah... that's too much to be normal blow-by.
      01-14-2020, 09:58 AM   #6
doodlebro
Drives: '17 X3 35i
It can also leak/weep past the vacuum line that connects before the throttle body. Might be worth buying some better O-rings, hardparker had a thread on the F30 side discussing this.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP
Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280'
      01-14-2020, 06:26 PM   #7
EndoDoc
Can you link to the post on that topic? Wish I could see a picture of where I should be looking?
I'll check the vacuum line when I upgrade the Orings, would it be worth upgrading the charge pipe as well to aluminum?
      01-16-2020, 08:28 AM   #8
TheCoolX3
Yes. Will save you many headaches in the future.
