      10-30-2018, 01:04 PM   #1
scostu
scostu's Avatar
Drives: 2016 F25
Bimmercode Help?
I recently moved from a 2014 F31 to a 2016 F25.
I've used Esys and Bimmercode on my wagon. Loved both but Bimmercode is way more user friendly and I no longer have a laptop for Esys.
I'm changing the front left/right turn signals on the X3 to LEDs. So I need to code off the cold/warm checks and change the bulb to LED.
On the F30/F31....this was done in the FEM_BODY.
When I hook up Bimmercode, I find no ECU labeled FEM.
Any help would be greatly appreciated!
      10-30-2018, 02:41 PM   #2
pokerface
pokerface's Avatar
Drives: F25 X3 N20 / F80 ZCP
I saw mine under Front Electronic Module (FEM_###)
could it be a version issue in Bimmercode?
      10-30-2018, 03:18 PM   #3
scostu
scostu's Avatar
Drives: 2016 F25
I'm running the latest version...2.14.
Not getting an ECU for the FEM_ when I plug into the X3.
      10-30-2018, 03:36 PM   #4
Wgosma
Drives: 2012 F25 X3 28i (N52)
Scott
Look under footwell module, I think-
I don't see FEM and I'm running same B-code version you have.
But...the guy has bugs to fix- I recently contacted Stephan and he verified that the reason I could not code actual pressure readout on TPMS was that he dumped off that coding in this latest version, by mistake..it was there 2 months ago in prior release.
May be similar issue here(?)- it's possible.
Good luck/Bill
scostu1623.00
      10-30-2018, 04:49 PM   #5
scostu
scostu's Avatar
Drives: 2016 F25
Originally Posted by Wgosma View Post
Scott
Good luck/Bill
I saw that ECU. I explored it briefly in expert mode.
Guess I'll need to do a deeper search in Footwell ECU.....thanks!
      12-18-2018, 08:46 AM   #6
x3sm
x3sm's Avatar
282
Drives: M3 E93 Porsche
Trying to figure this out now for LED bulbs, kinda nervous going into expert mode. Can anyone walk me through it?
M3 E93
PORSCHE MACAN S: SOLD
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
      12-18-2018, 09:19 AM   #7
scostu
scostu's Avatar
Drives: 2016 F25
Yes...give me some time as I'll need to walk through the different settings again in expert mode.
I'll update you as soon as I can.
      12-18-2018, 09:37 AM   #8
TheCoolX3
Drives: 2016 BMW X3 35i M-Sport
They have removed a lot of features on bimmer code. Kinda sucks.... most things you do have to do in expert mode. Worst of all they removed my RR bongs!!
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others
Instagram @TheCoolX3
      12-18-2018, 10:07 AM   #9
x3sm
x3sm's Avatar
282
Thank you, will be waiting!
Really? that sucks, I wonder why they did that. The reason why I chose Bimmercode over others is cause of the potential of using expert mode
Does anyone know if you can code fogs to LED signal in bimmercode? Since I converted to OEM BMW led fogs, they need to be coded as well.
Thanks forum.
M3 E93
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
      12-18-2018, 10:44 AM   #10
Riick
People fucking up their cars and blaming bimmercode.
      12-18-2018, 11:25 AM   #11
TheCoolX3
Anyone able to code the door handle lights when in reverse?
      12-18-2018, 11:45 AM   #12
Riick
Coding a BMW is only turning on/off/registering features that exist in the ECU that BMW enables or disables depending on what model car the ECU is in or for diagnostic purposes (like turning off monitoring for dead lights). You can however turn things on or off not for your specific model and really screw stuff up.
You can not create custom features like turning on door handle lights with the doors closed when reversing. There would be no purpose to have that feature in the ECU since that would imply exiting/entering a moving vehicle.
In fact, it's such a safety concern I do not think you can even remove the feature when reversing if you open a door the car will go into park. Too many people have killed themselves over getting out when still in reverse and running themselves over by mistake.
      12-18-2018, 11:58 AM   #13
TheCoolX3
I've seen many BMWs that have that feature coded in. From a few 3 series to M cars I just have not seen a way to do it in the X3. I know it is something that can be done.
      12-18-2018, 12:02 PM   #14
TheCoolX3
Answered my own question.. found this on an F80 forum, will try later today.
      12-18-2018, 06:57 PM   #15
Riick
Why tho?
      12-18-2018, 07:26 PM   #16
TheCoolX3
Helps you see stuff in the mirrors at night while in reverse.
Why tho?
      12-19-2018, 11:01 PM   #17
x3sm
x3sm's Avatar
282
Update! Figured it out.
You would need to go to FRM, than use expert mode and input the values below in the link
https://x3.xbimmers.com/forums/attac...8;d=1352055748
Now I'm trying to figure out how to stop LED fog light flicker and malfunction light. If anyone knows the German value for fog light, let me know!
M3 E93
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
scostu1623.00
      12-20-2018, 08:31 AM   #18
TheCoolX3
I too can not find the FEM Module so any guesses what module I could find 3070 - OVT BEI RUECKFAHRLICHT?
      12-20-2018, 08:50 AM   #19
scostu
scostu's Avatar
Drives: 2016 F25
Yep....no FEM on F25 chassis.
      12-20-2018, 09:35 AM   #20
x3sm
x3sm's Avatar
282
From what I remember you cannot code LED door handles to come on during reversing on the F25, I think it has been discussed in the F25 section coding thread.
Does anyone know if you can code LED fog lights to be brighter?
Thanks
M3 E93
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
