      10-07-2022, 07:55 PM   #1
kovacshuni
Drives: BMW X3 2013 F25
Is this sound the timing chain problem?
See if you can tell this means I have to change the timing chain and all tensioners. Or is this something else, like rubber bands?
More audible in wet weather conditions, with cold engine. The other day I was at the mechanic, they changed all sorts on it, listened to it, they didn't hear a thing, couldn't show them this sound then.
BMW X3 F25 2013
270.000km. Don't know if it ever was changed.
Thank you,
      10-08-2022, 10:16 AM   #2
x3aniac
Drives: BMW X3
Sounds like the serpentine belt. I have the same sound on my X3 20D. And that wheel thingy, what is it can't remember vibration damper or whatever is wiggling like crazy. Don't take my word for it. But look out.
      10-15-2022, 04:39 AM   #3
MSport_Jon
Drives: X3 F25 LCI /// F80 M3 (SOLD)
I agree. sounds like the accs belt. Can you spray a little bit of WD40 to see if it temporarily goes away?
      10-15-2022, 01:50 PM   #4
Bdavi011
Drives: 2013 BMW X3 3.5i
Remove the belt and turn on the car. Is the sound still there? If not, then it's your tensioner/belts. Might as well replace them.
      10-25-2022, 03:01 AM   #5
kovacshuni
When I spray even with water, it goes away temporarily. Thank you guys for the replies. I’m relieved that it’s not the chain.
Will replace the belt when I get to a service.
