      10-06-2019, 01:30 PM   #1
FranzX3M
Drives: '13 X3M
MAP sensor voltage
Hi, having issues with my '13 N55 X3 and I may have pouched the map sensor when trying to clean the intake valves with chemical spray through the PVC intake. What should the normal map sensor voltage be at atmospheric with the engine off and ignition on? With MHD monitor I'm seeing just over 3V. Also what should it be at normal idle? I'm seeing about 1.9V and at cruising I'm seeing 1.9- 2.1V. No engine codes. Lambda appears normal in mid 14.
Thanks,
