      10-06-2019, 03:10 AM   #1
valks1
Drives: BMW X3 F25
Drivers door lock actuator
Hi
From doing various test and replacing a fuse, i think my door actuator is broken.
I am looking to get a second hand replacement part.
Does anyone know if the part has been the same through the years?
I have a early model 2010 F25. Would the part from a later car fit or was there some changes to it?
Can anyone help?
      10-06-2019, 09:18 AM   #2
Opie55
Drives: '15 650i Convertible
Go to RealOEM.com, type in the last 7 of your VIN and find the part on the correct diagram. That will give you the part number. Google that part number and you'll hopefully find used ones for sale.
      10-06-2019, 10:25 AM   #3
valks1
Drives: BMW X3 F25
Thank you.
Seams like there is loads of part numbers for the same thing.
Does thus mean as long as i find a part with one of these part numbers it will work?
      10-06-2019, 11:02 AM   #4
Opie55
There should only be one part number. Real OEM will show various parts number options usually - like it might say "w/comfort access" or "w/o comfort access" or some such thing, and it may show the passenger and driver side as different parts, but once you narrow it down to the correct door and your correct options, it should be one number. If you click on the number in the parts list below the diagram, it will take you to a different page for just that part. It will show any part numbers it supersedes, and what the current number is. If it's still not clear, post the last 7 of your VIN and I'll look.
      10-06-2019, 11:21 AM   #5
valks1
Drives: BMW X3 F25
Thanks
My vin id LL17297.
Any help would be good.
I just need to know of any part numbers i could buy from ebay.
Cheers.
