02-19-2011, 04:42 PM | #1 |
Rep 18
tire wheel question for X3
Hello all,
I had a 335i BMW for only 45 days due to continuos car trouble. The BMW gave me a fare traede for a X3 Base model. I had winter tire/wheel combo for the 335i; below are the measurements. Will they fit the X3? 235/40R18 XL Pirelli Winter 240 Sottozero Serie II Blackwall wheels: MR118(Black Painted). Please advice and thanks to all. Barbara |
02-19-2011, 06:07 PM | #2 | |
Rep 1,271
02-20-2011, 08:30 AM | #4 | |
Rep 1,041
Those tires have a load rating that is 16% lower that the correct tires for a X3, so you would have to run much higher air pressure to properly support the car. That will lead to a very uncomfortable ride, and an even higher chance of sidewall damage because of the low ("40" aspect ratio) profile. Also the tires are 9.4% smaller in diameter, that means they must turn 9.4% more revolutions/mile. Your speedometer will read 6.6 mph HIGHER at 70 mph. Your fuel consumption will also increase slightly because of the higher engine revs. You won't be happy. Of course, if the wheels fit, if you don't do any high speed driving with those tires, if you don't drive any long distances, if you NEVER hit a pothole, if your local roads are billiard table smooth, and you don't care about having an accurate speedometer, you MAY be OK with them.......sorry! |
