02-10-2022, 10:54 AM | #1 |
Rep 16
Headlight upgrades?
So I am now an owner of a F25 (2015) 2.8i.
After my old E53 4.4 (waiting to be repaired) I have too many things I am happy with and some minor things that I am not.. 1. Halogen headlights (compared to my E53 xenons) 2. Hifi Sound (compared to my E53 DSP) I can live with the sound for a while but the headlights definitely need an upgrade. I have seen some people switching to OSRAM Night Breaker H7s and some switching to VLED Micro Evolutions. Recommendations and opinions please? Cheers, Ozzie |
02-10-2022, 11:38 AM | #2 |
Rep 101
It's a lot more work than plug n play, unfortunately. I'm sure it's been done someplace before but it's going to be $$$ and a lot of work. So much it may be cheaper to sell and buy one with a lighting package. (I had a headlight damaged then replaced, it was $700 for used and $1100 for a new one- I have old pre-lci xenon)
The biggest problem will be power. If I am not mistaken they have different wiring and power supply. So wiring to the FRM would have to be modified. If you got them powered properly and communicating with the car then you would need to VO code the respective lighting package on every model that deals with the lights (FRM, ICM, maybe KOMBI) I would start with checking out newtis.info and comparing the wiring diagram for halogen and Xenon or LED. Good luck! It's unfortunate people skip out on these packages to save $900 when in my opinion should be standard safety equipment. |
02-10-2022, 11:47 AM | #3 | |
Rep 16
The upgrade options (Osram and VLed) I mentioned are supposed to be both plug and play. Basically just bulb changes and that's what I am hoping to do.. Cheers, Ozzie |
02-10-2022, 01:21 PM | #4 |
Rep 2,551
Welcome to the forum...
Since drop in LEDs are illegal and blind other drivers with excessive glare, I'd recommend upgrading the existing bulbs with better ones, but don't expect a dramatic improvement. Those Halogens headlights just suck, I stayed clear of anything without Bi_Xenon when I was looking since much of my driving is on pitch black country roads. https://arstechnica.com/cars/2020/03...ermarket-leds/ |
02-10-2022, 02:40 PM | #5 | |
Rep 16
We were given the F25 X3 option when were looking at E83s and we took it after a quick research. It had everything we wanted (I was not so sure about N20 engine but I like it more and more everyday I drive it). Honestly I never thought it would come with halogens. I also did not like the red rear indicator lights (I prefer orange) but apparently that is only a choice in Europe (and a replacement is around $600). Cheers, Ozzie |
02-10-2022, 03:22 PM | #6 | |
Rep 2,551
These will be the brightest bulbs for your headlight, get (4) and a spare or so. Look for "H7 Ultra High Output Vosla" 2100 lumens vs 1350 for stock. https://www.danielsternlighting.com/.../products.html |
