05-11-2021, 05:59 PM | #1 |
Rep 54
Drives: 2014 X3 xDrive35i
iDrive inverted color/flickering
I took my 2014 BMW X3 in for detailing, and everything was fine at drop off--but they mentioned that after steaming the vents, the iDrive screen was flickering (uhoh). This was a high-end detailer so I was a little shocked.
Here is a short video of the issue: View post on imgur.com Many of the reports I've found seem to be unrelated or look like very different issues. Before I bring this in for what I suspect will be a typical costly repair, has anybody else seen this? |
05-11-2021, 06:15 PM | #2 |
Rep 349
Almost certainly it's one of the connecters. Likely due to moisture. It may simply require waiting a couple days for it to dry out. Or you could put the whole car in a bag of rice.
05-11-2021, 06:20 PM | #3 |
Rep 54
Hmmm, seems like a Costco run might be in order... Any idea if I can speed the process along (i.e., is this a common problem where the connector is known?) |
archangel24z3.00 |
05-12-2021, 11:58 AM | #4 | |
Rep 49
05-12-2021, 02:38 PM | #5 |
Rep 360
I'd pull the screen out, you could actually put that in a bag or rice, or out in the sun to dry, and if there is water in the connectors this would allow that to dry too. Pretty easy to do.
Step 1 - Pull the trim with the vents and start/stop button straight back, it's just clipped in. Step 2 - let that trim panel hang down. Step 3 - Unscrew the screen. Two screws on the bottom corners are now accessible. Remove them. Step 4 - Pull the screen out. Pull the bottom part, it will swing out, unplug the plug in the rear, and finish pulling out. It's really a quick process, so I'd give it a go. If the screen is toast, then a used one shouldn't be that expensive, probably under a couple hundred bucks. The hard part is making sure you find one where the antiglare isn't all scratched up. MSRP on a new screen is about $2K...Obviously if you have to buy a new one, I'd be going back to the detailer for that.
Current:
2017 F87 M2 6MT 2013 F25 X3 3.5i 2008 E90 M3 6MT |
