      03-20-2013, 08:23 AM   #1
lair12
Drives: 2012 X3 35i, 2016 X1, 2020 X3
Need to find circuit with power only when engine is on.
I'm having problems with my new amps conflicting with the comfort access system antennas. To resolve this, I need to find a fused circuit (preferably in the right trunk fuse box) that does not get power until the engine is started.
Any idea what fuse or electrical circuit item does not power up when the doors are opened (and waits until the engine starts), and then loses power as soon as the engine is shut off (and before you exit the car)?
      03-20-2013, 09:39 AM   #2
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
YOU are looking for trouble lol
      03-20-2013, 10:03 AM   #3
lair12
To clarify, I need to find a spot for the remote-on wire. Right now, the amp goes on when the door is unlocked, and conflicts with the comfort access signal. I need to delay the amp turn on until the engine is started, and then have it go off when the engine is stopped.
      03-20-2013, 10:42 AM   #4
nyalpine90
nyalpine90's Avatar
7433
2016 BMW X4  [9.33]
ac,headlights are activated when engine is turned on
      04-01-2013, 07:19 AM   #5
iride4u
Drives: 2014 X1 35 M-Sport Dinan
Car Toys found a circuit behind the sound system on my X3. I would be very careful about taping into any circuit with the CanBus. On my K1600GTL I had to build 3 separate circuits to keep the CanBus happy. Everything is controlled with relays and fused.
      04-01-2013, 11:01 AM   #6
lair12
Found the answer at fuse #24 in the front box. Works well for my needs. All fuses in the rear have power when door is opened.
