      05-25-2015, 03:16 PM   #1
Radioactive
Drives: '11 X3 28i '10 535i '04 325i
AIR FILTER REPLACE/INSTALL N52N (28i)
I tried to follow a few other posts on different forums on replacing the air filter on a 2011 28i w/ N52N engine with no luck. Here's how I did it. If you screw up your car following my explanation it's your responsibility.
I did NOT unclip the air filter muffler box before removing.
First thing I did was disconnect the air mass sensor (can remove completely by unscrewing the two torx screws) and then disconnected the rear air duct.
Second, I disconnected the two clip connects on the wiring harness to the rear of the muffler.
There is a suspension screw cover to the outside of muffler that is just a cover and lifts out. Then I slid the whole muffler box straight up and out. Unclipped and replace with new filter.
To reinstall, the muffler has a "Lip" on the front air duct opening that fits into the "female" portion on the front air duct. I then slid the whole box down and reinstalled the air mass sensor connector, rear air duct and wire harness clips.
