07-15-2011, 09:21 AM | #1 |
Rep 59
Road Paint on wheel wells
Came back from Toronto and drove over some freshly-painted lines on the roads. Hard to avoid as it was a 2-lane highway and had to drive close to the paint truck in order to pass. So here I'm, 3 days later, wheel wells full of yellow road paint. Mostly on the wheel wells and I was able to scrap off the plastic parts but the rear wheel wells is more of a felt material and it's hard to get rid of. Any suggestion? I have tried high pressure washer but no luck.
07-15-2011, 10:53 AM | #2 |
Rep 1,041
If pressure washing does not remove it, it's obviously completely dried. Gel paint remover might work, but would probably also damage the wheel well liner.
I'd remove the wheels, mask around the wheel flares and spray it with some flat black paint or even some spray undercoating. http://www.autogeek.net/under-coating.html |
07-15-2011, 10:59 AM | #3 |
Rep 12,276
You could try cleaning it with some denatured alcohol or mineral spirits and a brush. Otherwise, as Lotus recommended, you may wind up painting over it with a flat black.
I think it is bad luck to be superstitious |
07-15-2011, 11:05 AM | #4 |
Rep 372
Drives: 2006 330i, 2011 X3 , 2000e39
Or let the impressive amount of brake dust eventually cover it all up.
2006 330i: Titanium Silver, Black Leatherette, Navigation, European Delivery.
2011 X3 35i, Alpine White, Premium, Technology, Sport Package |
