01-18-2012, 11:01 AM | #1 |
Rep 702
No run flat tires?
I'm mounting a set of M6 replica wheels soon, and the tires I opted for are not run flat. Since there is no spare tire, is it best to keep a can of "fix a flat" in the case of a puncture, or is there a better alternative?
2014 BMW 328i Sportline--Arctic White/Black, 8 speed
01-18-2012, 12:53 PM | #2 | |
Rep 325
Drives: 2011 X3 xDrive 28i
My winter tires are non-RFT and I have got the CAA membership just in case..... |
01-18-2012, 01:17 PM | #3 |
Rep 1,344
BMW Mobility kit is available, comes with the Ms.
http://www.unitedbmwonline.com/bmw-m...-kit-1420.html Tirerack also has the continental kit. http://www.tirerack.com/accessories/...Tire+Inflation
21 BMW X5 xDrive40i
20 BMW M2 CS 19 Mini Cooper S Countryman ALL4 6MT |
01-18-2012, 02:59 PM | #4 |
Rep 274
You might be interested in my experience with this:
http://x3.xbimmers.com/forums/showthread.php?t=626527 http://x3.xbimmers.com/forums/showthread.php?t=625427 |
01-19-2012, 08:45 AM | #5 | |
Rep 702
01-19-2012, 08:49 AM | #6 |
user
Rep 229
01-19-2012, 09:02 AM | #7 |
Rep 702
I figured that, but there is really no other option since there isnt a spare correct? (other than having run flat tires, which the new ones are not in my case)
01-19-2012, 09:26 AM | #8 |
Rep 876
Definitely avoid tire sealent at all costs unless there is absolutely no other choice. ** It is an absolute mess inside the wheel when they go to replace it.
Personally, I'd keep a small air compressor and a tire plug kit. Any leak that slime could fix you can fix with a tire plug. There could be a rare occurance where you get a pin hole leak in the sidewall and in that case I would avoid the tire plug, but in all other cases the plug should work. ** With the above being said, the plug/compressor approach takes a bit more effort and motivation to fix a tire compared to the slime. Not knowing your exact situation maybe slime is your best bet, but just be ready for a potentially faulty TPMS and/or a small cleaning charge tacked to your bill when you have the tire plugged or patched. |
01-19-2012, 09:33 AM | #9 | |
user
Rep 229
tire repair kit |
