06-25-2021, 10:29 AM | #1 |
Rep 6
Tyre pressure monitor failure rdc
Just had this on the car. On the little silly screen
Checked all tyres they are fine Looking on websites seems to be issues with the module behind the driver side rear tyre No damage. Any suggestions? Thanks Chris And the air con and fan went crazy on off speed up down really weird |
06-25-2021, 10:57 AM | #3 |
Rep 6
06-25-2021, 11:04 AM | #4 |
Rep 1,906
If the battery is more than 5 years old it may be worth verifying it is performing properly- just a thought, batteries as you probably know don't last forever and these cars are sensitive if system voltages are marginal.
06-26-2021, 01:25 AM | #5 |
Rep 6
Ok booked in today for a check will ask for battery check too
06-26-2021, 04:25 AM | #6 |
Rep 350
The typical failure with the RDC module is moisture causing corrosion on the circuit board. Sometimes you can crack the unit open and clean up the corrosion to save it. I had mine fail this last winter but it was too far gone. Once installed, the new unit does require coding for the car to recognize it. Dealer replacement isn't cheap.
Wgosma806.00 |
