      08-07-2015, 04:32 AM   #1
msb100
Drives: X3 30D F25
Help Diagnosing Noise
Hi,
I have a 2012 F25 X3 and I've started hearing a Knock sound when going over a speed bump or a pothole from the front right side.
The sound is heard if the tires/steering are pointing straight or to the right. If the tires are pointing to the left, there is no sound.
Also, the sound comes on when the Tire is moving downwards.
Can anyone help in diagnosing where the sound is coming from and if it's something that I can fix?
Thanks
      08-07-2015, 07:28 AM   #2
mge92
SPEED RACER
mge92's Avatar
Drives: BMW X5 M50d BMW M2 CS
Originally Posted by msb100 View Post
Hi,
Thanks
Could be suspension related like the balljoints. Would suggest bringing it into the dealer.
2019 BMW X5 M50d Artic Grey | 2020 BMW M2 CS Misano Blue
Incoming - Ginetta G56 GT Academy | Incoming - BMW X5M Comp Oxford Green
RIP - 2020 Mini JCW GP Racing Grey | RIP - 2013 X3 xDrive28i Carbon Black
      08-07-2015, 08:43 AM   #3
MartinHattingh
MartinHattingh's Avatar
South Africa
22
Drives: 2012 X3 XDrive 2.0i
India is right-hand drive, correct?
If so, what you're hearing is most likely the very common steering rack issue. Mine does the same.
Perform a search for steering rack issues, you'll see that many owners have had them replaced, only for the noise to start reappearing not long thereafter. I've learnt to live with it and see it as a "design flaw", which unfortunately it is....
      08-07-2015, 01:04 PM   #4
msb100
Drives: X3 30D F25
Hi, RHD it is. Thanks for the heads up, will search the forums for possible fixes.
Thank you.
      08-07-2015, 03:04 PM   #5
momoboy
Drives: F15 35i 2017
I had the same noise. Replaced the steering shaft first but dealer still heard a noise. Steering rack was replaced as well. All quiet now
      08-08-2015, 09:09 AM   #6
msb100
Drives: X3 30D F25
Found this..http://www.e90post.com/forums/showth...=761080&page=2
Will check.
      08-10-2015, 05:14 AM   #7
kkk
Drives: X3 3.0d msport
x3 3.0d steering noise
My car is just 1 week old and run 250 km when the clunking/knocking noise started. My Mitsubishi Outlander had the same defect but after running 5000km. Same thing in BMW. Its really annoying to get the sound when driving our a bump or a speed breaker when the knock comes through the steering. With all the technology cant design a noiseless steering.
However the same can be fixed in a couple of hours by the local turner shop which BMW cant make from the very beginning. But that would void the warranty of the vehicle. So no choice but to take it to the dealer and ask for a solution.
      08-10-2015, 06:17 AM   #8
msb100
Drives: X3 30D F25
Can you please share the details on how this can be done? Thanks.
      08-27-2015, 11:47 AM   #9
kkk
Sorry for the delayed reply. This would involve removal of the steering rack and giving it to specialised turner shops which can adjust the tolerances between the components inside the steering rack using special tools and may include replacement of the bushes etc. I have got the steering racks of my older vehicles which usually have run 40-50000 km over indian roads serviced from such shops and the cars have become noise free after performing this service. However BMW in India does not recommend this although the steering racks that come on our cars have an adjusting nut to tighten the steering to eliminate the rack noise, BMW does not even recommend this method. They would just outright cancel the warranty if they realise that this setting has been changed. So if you are ok with the warranty being void it can be fixed outside. However i would not be comfortable with this since my car is not even a month old.
