02-01-2022, 08:39 AM | #1 |
Rep 832
Battery Replacement 2016 U.S. X3 2.8 xDrive
I need a new battery for a 2016 X3 2.8 xDrive and I cannot find one. Dealer has no inventory and no ETA on back-order. I am told it is a 105AH AGM. The original 80AH (?) seems no longer on sale.
Anybody have an idea where to get a fitting battery? Thanks.
Hoc Lapidem Non Vi Sed Saepe Cadendo!
02-01-2022, 08:59 AM | #2 |
Rep 184
I replaced my wife's battery in her 2016 X3 Sdrive28i last month. The original was a 105ah and the dealer had the replacement 105ah in stock. I think you'd be fine with a 105ah instead of a 80ah, you just wouldn't want one that's less than that. Someone will correct me if I'm wrong. I'd say you should be able to find a suitable AGM battery at just about any auto parts store.
02-01-2022, 09:21 AM | #3 |
Rep 1,911
Should be at most any parts store as mentioned- I had Pep Boys install and register AGM battery in my 2012 X3 about 3 years ago- $215, reasonable price.
02-01-2022, 09:47 AM | #4 |
Rep 184
Yeah, I forgot to mention cost. Dealer charged $208 for the battery and I paid the $30 for Bimmerlink to register it myself. None of the local parts places could register it for me. Figured I'd probably need to do it again at some point. Although the original battery lasted 6.5 years with periodic charging via a battery tender.
Wgosma809.00 |
02-01-2022, 10:56 AM | #6 |
Rep 5
I just replaced mine. Original was 90Ah, but I replaced with a 105Ah (both AGM).
I had to change the Ah value coded with bimmercode, and then register the new battery with bimmerlink. Kinda annoying that you need both apps to complete the process, but I had them anyway. |
02-01-2022, 02:22 PM | #7 |
Rep 3,602
It's probably already been well said, but to add on, yeah you can get a bigger one. Just be sure it's not larger than I believe "H9" and that it is AGM. I feel like I started with H7 and know that I put in an H9. I think they are just a little wider but still lock into place.
I coded with the Carly app but also already had it. Used it to get rid of the seatbelt reminder gong (I use the belts, just hate the noise), the disclaimer screen, and so forth. |
02-03-2022, 01:07 PM | #8 |
Rep 101
Got an Interstate MTX-95R/H9 (100aH / 950CCA) on recommendation from the dealership since they've been unable to order for 6+ months, was near half the price of what BMW wanted for their nonexistent battery, and got it registered for free with another service at my local indy shop. It's turned the car over no problem in 5ºF weather after sitting for a couple of days and start stops flawlessly.
tracer bullet2487.50 |
02-03-2022, 01:43 PM | #9 | |
Rep 2,551
You'd think 105 would slightly overcharge it while 90 would undercharging it. Undercharging seems better for the batt than overcharging |
02-03-2022, 05:07 PM | #10 | |
Rep 101
02-03-2022, 07:23 PM | #11 | |
Rep 350
1986 Delphin 528e - Roof rack equipped lumber hauler.
2008 Platinum-Beige X3 3.0si - Current project 2012 Alpine White X3 xDrive35i - My new snowmobile. 2020 Estoril Blue 440i xDrive cabrio w/MPPSK - This car is a blast to drive. |
02-06-2022, 12:22 PM | #12 |
Rep 253
I still don't know why my replacement attempt from an auto parts store went awry. Maybe something wasn't tight, though I double checked everything. Things were so bad that Carly thought about everything was failing, and car would crank but not start, etc.
Luckily for me, I tried a different BMW dealership which was about 1/2 the closest dealership to me, so my net cost wasn't that bad. |
02-07-2022, 05:55 PM | #13 |
Rep 350
I finally got around to replacing my battery today. My 2012 originally came speced with a H8 90 Ah battery. I replaced it with the AutoZone Duralast H8-AGM. It wasn't rated for Ah, but other specs were the same as the Advance Auto DieHard brand so I'd guess rated right around 95Ah. In picking one out, I came to the realization that if your original was AGM
105 Ah, you want an H9-AGM battery 90 Ah, go with H8-AGM 80 Ah, go with H7-AGM Those are also the 3 sized that physically fit. Do that and you should be close enough. Why BMW specified it using Ah, a measure of storage batteries, not starting batteries, I'll never know. Also, current battery was the original one from 2012. It was on it's last legs but still continued to start the car. I ran the history function on it before I replaced it and it was only getting around 60% charge. Usually that was enough except when it was well below freezing out. Then it would just get flakey. Most often it wouldn't detect the key via the comfort access system right away. I'd wait a few moments and just try again. It probably helped that the 2012 doesn't have stop/start.
