      11-19-2014, 09:47 PM   #1
Radioactive
Drives: '11 X3 28i '10 535i '04 325i
Question on VANOS recall/extended warranty
I just received a letter from BMW informing me that it has extended the warranty on the 28i engine VANOS Adjustment Units. Anybody know if these "Units" are the same as the bolt recall on the 35i or is the bolt part of the "Unit"?
Has anybody had a problem on their 28i with the VANOS?
Thanks
      11-20-2014, 01:25 AM   #2
bimmeupscotty
Drives: 2015 X3 xDrive 28i
what year is yours ?
      11-20-2014, 07:48 AM   #3
Radioactive
2011...N52t engine
      11-20-2014, 10:14 AM   #4
E90Fleet
South Africa
1312
It is for the same bolt problem.
For the ones outside the production range where the vast majority of bolt failures have occurred they extend the warranty as you are unlikely to have any problems. For engines in the production range where bolts are failing they will replace the bolts.
You should have very little to worry about
BMW if you are reading, I need a job, Please.
