      05-12-2017, 11:55 PM   #1
Crassus
Drives: 19' G20 X3 20i & 19' M140i
Exclamation Tyre wear
Hello everyone
Yesterday I collected my car after a isofix recall repair. The dealer took the liberty to carry out a health check and noted down the below about millimeters of thread left on inner, middle and outer tyre.
NFS: 4.4, 4.6, 4.4
OSF(driver side): 4.0, 4.2, 4.4
OSR: 5.0, 5.2, 5.4
NSR: 5.2, 5.0, 5.0
The car is 12 months old, has done just over 8,000 miles, staggered pirelli runflat tyres with 19 inch alloys, mostly done short journey in areas with lots of elevation change, many roundabouts on gradient and generally poor British roads.
Is the tyre wear as you would expect? The inner driver side tyres is wearing quickly. Is it alignment related, if so, will I have to pay for a realignment? What's the outlook for my tyres in the next 6 months?
Thanks
Previous Bimmers: F25 X3 20d LCI xLine, F30 320d Luxury
      05-13-2017, 12:33 AM   #2
Tjalle
Drives: X4 35i
I have experience from 20" staggered Pirelli P ZERO Run Flats:
-overall wear is high . New are 9 mm.
-wear is even - no problem there.
-yes an alignment would cost you - no need.
-my wear is larger in rear, due to rear wheel drive bias and 300+ bhp?
-since you started with 9 mm, you can do the math. Legally, I believe you should have about 2mm, and being in the UK, I would not cheat too much
Michelin has best history of tyre wear,but expensive.
      05-13-2017, 03:59 AM   #3
Andy_o
Andy_o's Avatar
Drives: X3 20d Xline Melbourne Red
  [0.00]
2015 BMW X3   [0.00]
Originally Posted by Crassus View Post
Hello everyone
NFS: 4.4, 4.6, 4.4
OSR: 5.0, 5.2, 5.4
NSR: 5.2, 5.0, 5.0
Thanks
That doesn't look too bad to me
Lots of short journeys with stop and start .. lots of accelerating and decelerating .. possibly static steering wheel movements ... are likely to have an impact on front tyre wear more so than rear
Bearing in mind the X3 is a heavy car ., you've lost 3mm in 8k and have another 3mm or so till they hit legal limit .. so possible 16k out of fronts .. not bad really
Slight uneven wear not really an issue .., quite normal
If one side of tyre was down a couple of mm then I'd be concerned
Fwiw my car does mostly long journeys . I'm at about 3-4mm on 20k
Gone: E90 crimson red/black
Gone :X1 23d Msport manual, Space/Beige Pro Nav, Adaptive zenons, privacy glass, 18's, ext storage,
Current: X3 20d Xline auto, Melbourne/Beige, Sport seats, Viz pack, heated steering wheel, Folding mirrors, privacy glass, luggage net, pro nav
Current: E85 Z4 3.0si roadster titanium/Syrah individual
Current: F31 320d touring black/black work hack
      05-13-2017, 06:59 AM   #4
Peter_R
Air Vice Marshall
Peter_R's Avatar
@Crassus
You wear is normal for that mileage. About the same as I had with similar mileage with X3 xDrive30d MSport with 19" Staggered setup.
As you are most likely aware in the UK the legal limit 1.5mm is minimum tread depth with BMW recommending to go no lower than 3mm.
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
      05-13-2017, 02:25 PM   #5
Crassus
Thanks for the replies everyone. I'll try to drive a bit cautiously in hope that the tyres will last another 6-10 months before I replace the car with the G01.
      05-13-2017, 06:12 PM   #6
Northandy
Drives: BMW X3 3.0d M Sport
I have the 3.0d on the 19's
I get 18k a set, all wear out at the same time, currently on 37k so car has had two new sets of tyres so far
      05-15-2017, 03:01 PM   #7
AlphaMendoza
Admiral
Drives: X3 F25 LCI 20D
I have Pirelli P7 Cinturato on 17" wheels
Just replaced fronts with new P7s after 36k miles in 3 years; rears still have 5-6mm tread left
LCI 2.0D SE
Non Run Flats
I don't think I am driving like a wuss! Maybe non-run flats make a difference?
      05-15-2017, 04:50 PM   #8
Peter_R
Air Vice Marshall
Peter_R's Avatar
LCI 2.0D SE
Non Run Flats
I do not think you are driving like a Wuss! The 3 litre engines on larger wheels tend to wear the tyres out quicker for a variety of reasons that I do need to into here.
