05-30-2020, 10:50 AM | #1 |
Rep 14
Bimmercode said coding error for power liftgate module.
I recently replaced 14 X3 power liftgate module with a used one on eBay. The module can work without programming, but when I connect with Bimmercode, it said invalid coding error. Can Bimmercode program the module and I can code it later? Thank you everyone.
05-30-2020, 01:53 PM | #2 |
Rep 2,554
There might be a flash version mismatch with other module dependencies.
05-31-2020, 09:53 AM | #3 |
Rep 14
05-31-2020, 11:50 AM | #4 |
Rep 2,554
The dependencies are always there, you don't clear them. There are many modules that interact with each other and mostly need to be at a similar firmware version. Use E-Sys and see if it detects the module. If so code it from there. My guess is the module is from a vehicle much older or newer than yours. It can be flashed to match the rest of the vehicle's modules.
05-31-2020, 03:17 PM | #6 |
Rep 2,554
