      04-18-2020, 09:29 PM   #1
Chiefl954
Drives: 435i Gan Coupe
Cargo area squeaking
I got a 2017 X4 M40i and I hear a lot of squeaking in the cargo area. Anyone else have this issue or have found a resolution to it?
      04-20-2020, 10:20 AM   #2
couchflyer
couchflyer's Avatar
97
Drives: M4; X4 M40i
You have to adjust the back tailgate.
https://www.newtis.info/tisv2/a/en/f...ate/1VnYGUnVYN
      04-20-2020, 01:59 PM   #3
Chiefl954
Thanks for the info. Ill make an appointment at the shop for this since its still under warranty. The sound is so annoying.
      05-25-2020, 09:53 PM   #4
Chiefl954
Took it to the dealership and they took it apart and put felt in some areas. Less squeaking but its still there. So annoying.
      05-27-2020, 09:00 PM   #5
joyjoy22
Drives: BMW M4 2014
Did they you the reason behind the squeaking noise?
      06-05-2020, 07:47 AM   #6
Chiefl954
Plastic contact with the body. I still hear some though. I plan on taking it to another dealership for the same issue to see if they can do a better job at it
      08-20-2020, 04:44 PM   #7
tlojak1107
Drives: 2018 BMW X4 M40i
Im having the same issue, it sounds to me like it is the Plastic trim framing around the rear window that is rattling. Im going to take it to the dealer and address it next week. It is pretty irritating. That (so far) is the only complaint I have on this vehicle.
      08-22-2020, 07:44 AM   #8
XMBeast
Drives: X4 M40i
well, i also have the exact problem. A bit of squeaking while riding on uneven roads / potholes. I will see if they can do a DIY! i am not sure if the vehicle is still covered under warranty to get these things fixed.
      08-22-2020, 07:55 AM   #9
Chiefl954
I agree. It is kind of annoying. I have my appointment for this Monday at another shop to see what they can do. It does sound like its the plastic in the rear window. Not sure why BMW always seem to use cheap plastics.
      08-23-2020, 02:40 PM   #10
couchflyer
couchflyer's Avatar
97
Drives: M4; X4 M40i
My issue is evidently different that what you guys have. My dealership actually adjusted the rear hatch a bit tighter, then my noise went away.
      09-03-2020, 03:22 PM   #11
Chiefl954
Took the car to another dealer and they made some more adjustments on the door bumpers and added more felt. Noise gone.
