      09-13-2017, 02:05 PM   #1
Bruce24
Drives: X3 2.8i
Dash light that looks like an engine
On my MY'13 2.8i w/50K miles I have the yellow/orange warning light that looks like an engine illuminated. My first thought was this was a check engine warning, but when I looked it up in my manual and it says "Emissions in Canadian models". My car was delivered to me in Boston, so that doesn't seem all that helpful. When I check iDrive, I says everything with my car is fine.
I'm currently away from home, so I'm wondering if this is something I need to worry about immediately.
Thanks,
-Bruce
      09-13-2017, 07:26 PM   #2
Iowa X3
Drives: 2013 X3 28i
Can you post a picture of it? Because it sure sounds like the check engine light to me, but I haven't looked at the manual for the descriptions on these lights lately.
      09-13-2017, 09:12 PM   #3
Bruce24
Drives: X3 2.8i
It's to the right of the tach and looks like this.
      09-13-2017, 09:28 PM   #4
Iowa X3
Drives: 2013 X3 28i
Yeah, that's the check engine light.
      09-14-2017, 07:08 AM   #5
lovebimmers
Drives: 2013 X3 35I
You need to get it properly checked out. I had the exact same issue on my 2104 x3 35i with only 28k miles. Drove perfectly fine. It turns out it was the carbon canister that failed. Dealer replaced it for free since it was under warranty. Bill was $1k but free for me.
      09-14-2017, 06:10 PM   #6
Eaglesview
Drives: X3 28d
I have had that warning light come on twice on my 2015 28d. Service rep said no error codes and likely fuel cap not sealed properly. Will go away in 20 start cycles. Did not count start cycles but it went away.
      09-20-2017, 04:58 AM   #7
P1Fanatic
Drives: F25 30d M-Sport Alpine White
That light can be a multitude of reasons. Is there no more info displayed in the car info menu?
You could try an OBD reader to get the exact error code but they are not always displayed as I found out.
      09-22-2017, 02:36 PM   #8
TJNies
Drives: 2024 X5 40i
Many times the Check Engine light will come on if the gas cap has failed or improperly seated. It does take a few cycles to take effect and clear.
Also can by things within the emission system such as the mentioned canister, or even a simple air hose that has a hole or come off.
      09-25-2017, 06:26 PM   #9
Bruce24
Drives: X3 2.8i
I took my car into the dealer today to have them try and figure out what was up with the check engine light light. They diagnosed it as a fault with the thermostat where it was giving a circuit open error.
Per the invoice, they replaced the thermostat and coolant. There was no charge because BMW extended the warranty for the thermostat. Note my car is a MY'13 and I have 50K miles.
-Bruce
      09-27-2017, 12:11 PM   #10
lovebimmers
Drives: 2013 X3 35I
-Bruce
Do you know how long the warranty was extended for?
      09-27-2017, 01:57 PM   #11
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
well 2013 x3 is still at "4yr/50k" so ur still under warranty until u reach 51k.
      09-27-2017, 02:05 PM   #12
Bruce24
Drives: X3 2.8i
I bought my vehicle in August of 2012, so my warranty ended 13 months ago.
      09-27-2017, 02:11 PM   #13
Bruce24
Drives: X3 2.8i
I didn't think to ask. I just did a quick search and found this:
Service Bulletin No.: SIB-12-33-14
Component(s): ENGINE AND ENGINE COOLING
NHTSA ID Number: 10058476
All Products Associated with this Service Bulletin
Vehicle MakeModelModel Year(s)
BMW 3-SERIES 2012-2013
BMW X3 2013-2015
BMW X4 2015
0 Associated Documents
Manufacturer: BMW of North America, LLC
SUMMARY:
BMW: DUE TO TRANSMISSION OIL HEAT EXCHANGER'S FAULTY THERMOSTAT OR ENGINE FAULTY CHARACTERISTIC MAP THERMOSTAT, ENGINE COOLANT FAILS TO REACH OPERATING TEMPERATURE, WITH LOW HEAT OUTPUT AND SERVICE ENGINE SOON LIGHT COMES ON.
