      11-15-2011, 04:37 PM   #1
smoothmoka
Drives: f25
Anybody know how to add extra USB
Hi Guys!
I tried adding a USB (4) hub inside the armrest connection but no success. It won's read my ipod and usb key. Is there any way to add more USB input so I don't have to disconnect my iPod everytime I want to use a USB stick/key?
Thanks!
      11-15-2011, 04:52 PM   #2
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Originally Posted by smoothmoka View Post
Hi Guys!
Thanks!
System will accept USB hub if it can handle multiple USB ports, its not just a HW implementation. I am not sure of the OS used in iDrive. It looks as if it has dedicated ports type of implementation.
      11-15-2011, 06:43 PM   #3
MetaX
Drives: 2022 X3MC
Having two USB devices connected at the same time will probably confuse the iDrive system which was most likely designed to expect only one. Off the top of my head, the only solution I can think of that may work would be some sort of KVM type switch which allows you to connect multiple devices simultaneously but only passes through one device at a time (you select which port to be the active one).
      11-15-2011, 07:15 PM   #4
Nahoa
Use the one in the glove box?
      11-15-2011, 10:41 PM   #5
greg2step
X3 Owner/Driver
greg2step's Avatar
Drives: 2018 X3 M40i
somewhere in the manual - or perhaps a warning sticker it says the USB i the glove box is to be used for loading music to your library or software updates only.
2018 X3 M40i G01 | Phytonic Blue | Mocha | Premium+Exec | Driver Assist | Adaptive M Suspension
2011 X3 XDrive35i F25 l Deep Sea Blue l Mojave Leather l Sport, DHP, Premium, Nav/Technology, Cold Weather, Convenience [traded in]
2008 328XI E91 Sportwagon l Sparkling Graphite [traded in]
      11-15-2011, 11:51 PM   #6
Lotus7
Drives: xxxx
Not elegant, but quite inexpensive and should allow you to easily switch between an iPod and a USB flashdrive.
Manual USB Switch
      11-16-2011, 10:39 AM   #7
smoothmoka
Drives: f25
Thanks all for the response and suggestions.
I might just go the Lotus way ...but make it pretty.
      11-17-2011, 07:54 PM   #8
gareth12468
Drives: 2011 X3 xDrive 28i
2011 BMW X3  [0.00]
Canadian version didn't have that.....
