01-25-2024, 02:01 PM | #1 |
Rep 24
Battery replacement
Hello Spoke to the local dealer / parts
the 105AH relevant battery is with part # 61-21-5-A40-E33. Mentioned the old original part # 61212353814 is not available anymore. Is there any benefit with BMW brand battery vs. Say a Duracell ? Who is the actual manufacturer of the BMW brand battery ? Has anyone tried part # 61-21-5-A40-E33 in F25/X3 as replacement...is this an AGM ? Any alternate brand suggestions would be helpful ...to fit the 2014 X3 28i Thanks |
01-25-2024, 02:10 PM | #2 |
Rep 283
Drives: E46 M3 & LCI X3 35i M Sport
In my experience it's best to just buy the battery from the dealer and register it yourself. They're often the same price as elsewhere and you get an additional year of warranty for buying the "oem" battery.
I paid... $245 for mine a year or so ago which I was shocked by... in a good way. |
01-25-2024, 03:15 PM | #4 | |
Rep 1,906
mwat125.00 |
01-26-2024, 10:27 AM | #6 |
Rep 7,484
Yes, the BMW 105AH battery that you posted is an AGM battery. It says so right on the battery.
When I replaced mine back in Jan/2023 (see pics below)...with my BMW CCA discount...it was $227 out the door (with $18 core charge return). All the other H9 class size batteries being sold by other vendors in my area (at the time) were only 100 AH and they cost more. Batteries Plus did sell a 105 AH Duracell 95R/H9 battery...but they wanted over $300 for it. The other thing that I appreciated with the BMW branded battery is...it came with a little black elbow and additional plug in a little plastic baggy...which is needed to connect the new battery to the car's vent tube and to PLUG the other vent hole on the other side of the battery. You need to do this if your battery is enclosed inside the trunk or below the rear seat...any off gasses from the battery need to be vented to the exterior of the car and not released inside the car/battery enclosure.
Wgosma806.00 |
01-27-2024, 02:12 AM | #7 |
Rep 10
I, too, went with the BMW battery (61-21-5-A40-E33) since it was less expensive and higher capacity than the aftermarket alternatives. In Feb 2023 it was around $220 I think. Mine did not come with the elbow or plug; I had to transfer those over from the old battery.
I used BimmerLink to reset it. -Mike |
01-27-2024, 08:37 AM | #8 |
Rep 7,484
Just an FYI…if you purchase a battery from the dealer or aftermarket…if it does NOT come with the new elbow & plug in a little baggy stuck to the side…ask them to check if it fell off…or get one off another battery they have in stock.
Also, some aftermarket batteries won't come with the little black elbow (so make sure you keep your original)…and the extra plug may be built into one of the battery post covers…so be careful to not throw that away until you’ve removed the snap-out plug to insert in the extra vent hole in the battery (if you’re battery is in an enclosed area). Examples below shows the snap-out plug built into battery terminal cover on some aftermarket batteries:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 01-27-2024 at 01:40 PM.. |
FloridaNative3.00 X3rd Time Is a Charm2812.50 |
01-27-2024, 10:45 AM | #9 |
Rep 2,907
I got a Duracell 105ah battery for my X3 because I simply assumed the dealer would be more expensive. I was wrong, so when I needed one for my 650, I got it at the dealer. Takes 30 seconds to register with Bimmerlink.
Tags |
batttery, replacement |
