06-13-2022, 10:13 AM | #1 |
Rep 15
Undercarriage rattle when driving over uneven surfaces at low speed
Can anyone identify the source of this rattle on a 2017 F25 (28i)? Video attached, sorry for the shot of my bare foot as I just took it driving around the block this morning.
The rattle sounds like it could be coming from just behind or just below the firewall. Possibly front driver's side of the car. It's most noticeable at low speeds (when the cabin is quiet). Happens when going in a straight line as you see in the video. There's no obvious problem with the steering or suspension and I just did a 1200 km round trip over the past few days, with another 300 to go today. Wondering if it's just something that's worked loose on the undercarriage or maybe a suspension component that's worn out? Doing some digging around the forums had me wondering if maybe it's a strut mount bearing? Would that make this sound? |
06-13-2022, 05:44 PM | #2 |
Rep 15
Some more digging leads me to think it's probably the thrust piece, which seems to be a common issue for BMW.
Found the video below on Youtube, and realized moving my steering wheel back and forth with the engine off definitely produces the same clicking/knocking noise from the steering rack. I guess driving at low speed achieves the same effect. |
06-13-2022, 07:33 PM | #3 | |
Rep 2,551
I replaced mine with the revised part. The original part is susceptible to wear, therefore causing play in the rack. The new part has wear bars made from a more suitable material, plus has o-rings for less friction of the part I'm not saying that will fix your rattle, but an easy way to tell is to simply turn the adjustment on the original part to remove the play and see if the rattle goes away. There was a groove worn on one side of the old part from where the rack rubs: |
softsign7.50 |
