02-29-2024, 09:01 AM | #1 |
74
Rep 296
Drives: All BMW models
Location: Unit 32 Sundon Industrial Estate Dencora Way Luton Bedfordshire LU3 3HP
EVOLVE | Eventuri Carbon Intakes - Last Units Available
As an Eventuri dealer we have existing stock ready to ship! These are the last units we have available in stock currently, and with stock generally on back order, we wanted to give customers the chance to order immediately.
1 Unit Remaining: Eventuri Carbon Fibre Intake System - BMW F97 X3M | F98 X4M Acceleration Time : 60-130mph Reduced By 0.2 seconds Dyno Data : Coming Soon The X3M/X4M intake setup from BMW although awkard at first sight, is a very well designed system in the given space available. The flow path from the filters to the turbo inlets is very direct and does not change direction as abruptly as the usual OEM airbox designs. So instead of a complete redesign we focused on improving the OEM airbox with less restrictive flow and improved temperature efficiency. Eventuri have developed replacement drop in filters made from non-woven mesh which have a much higher flow rate as compared to the stock paper filters. To help reduce inlet air temperatures and force air into the airbox we designed large front scoops which sit behind the grills. The carbon scoops channel air into the ducts and effectively effectively de-restrict the inlet side of the airbox. The final piece is the carbon airbox lid which although doesn’t add to the performance, it does allow for a more audible induction sound and gives the engine bay a much needed aesthetic improvement. The Eventuri X3M/X4M intake system consists of a number of components engineered to perform a specific purpose and fabricated to the highest of standards. Here are the details for each component and the design ethos behind them: Each intake system consists of: 1 x Carbon Fiber Airbox Lid 2 x Carbon Fiber Air Scoops 4 x Direct Replacement High Flow Air Filters Laser Cut Stainless Steel Brackets PM me for pricing and delivery options |
Tags |
eventuri, evolve |
