      10-14-2018, 11:39 AM   #1
Sfkjeld
Drives: 2007 X3
After market brake rotor alternatives
Need rear brakes. Was hoping to avoid buying factory rotors due to cost and the relatively low resale value of 2007 X3’s with >100k mi. I put after market brakes on my Boxster. They work beautifully and cost <1/2 of the factory brakes.
But since the X3’s have a rep for marginal brakes anyway, maybe I need to stick with the factory set up?
      10-18-2018, 02:07 PM   #2
frisbeeguy
Drives: BMW,Tesla, etc.
You don't have to. If you want good bite-feel however, you'll need to stick with semi-metallic pads such as pagid or textar, but dusting is an issue. Otherwise you can do akebono ceramic pads. As for rotors, you can use pretty much any reputable brand. Pagid and Meyle (fcp euro lifetime warranty) are good.
      10-23-2018, 04:52 PM   #3
TURBO8
Drives: 2011 135i
R1 concepts drilled and slotted rotors, kinda surprised at the quality of these, paid ~$200 for front\rear rotors and brake pads. Newegg.com has them with free shipping and 25% off coupon. You can get them cheaper without the slots\holes.
      10-23-2018, 05:42 PM   #4
Sfkjeld
Drives: 2007 X3
Great, thanks. Where did you get the 25% off coupon? And to confirm, you put this setup on an X3 and the braking is fine?
      10-24-2018, 12:28 PM   #5
TURBO8
Drives: 2011 135i
Yes, on my 2004 E83 X3 3.0 and the braking is good. You will need to bed them in correctly.
https://www.newegg.com/Product/Produ...9SIA2GG5N81492
I guess they got rid of the 25% off coupon and just reduced the price.
Originally they were $280 for the set.
You can also try these
https://www.newegg.com/Product/Produ...2853-_-Product
I also put a set on my 135I, no problems.
      10-24-2018, 03:56 PM   #6
frisbeeguy
Curious as to how these are compared to the stock ones?
      10-24-2018, 10:56 PM   #7
mweine
Work Hard! Play Harder!!
mweine's Avatar
Drives: BMW 1M, BMW M3 CS
1989 BMW M3  [0.00]
Need rear brakes. Was hoping to avoid buying factory rotors due to cost and the relatively low resale value of 2007 X3's with >100k mi. I put after market brakes on my Boxster. They work beautifully and cost <1/2 of the factory brakes.
But since the X3's have a rep for marginal brakes anyway, maybe I need to stick with the factory set up?
Remmen brakes has cross drilled and slotted rotors for the E83 X3. Prices shown are for 2 rotors which is very reasonable.
https://www.remmenbrakes.com/?make=2...ion=vpf-search
Also the E90 335Xi callipers and rotors fit the E83 X3 (interchangeable)
