05-18-2018, 10:23 AM | #1 |
Rep 825
BMW iDrive Map Zoom Direction
Has anyone noticed that BMW seems to have swapped their zoom-in/zoom-out direction for this generation of the X3 (or iDrive)?
I took one for a test drive (X3 M40i) at a BMW event recently and kept getting thrown for a loop when I zoomed in and out on the map. Now clockwise zooms in and counter-clockwise zooms out. I'm 99.9999% sure previous generations (F, E), it was the exact opposite (and counter-intuitive to me) to screw something in to zoom out and screw something out to zoom in. Anyone else?
Down for Maintenance
05-18-2018, 10:26 AM | #2 |
Rep 182
You are correct. It took me some time to get used to the zoom in/out direction on the previous generation. I'd just about got used to it and now I'm forever rotating the controller in the wrong direction in the G01 X3.
05-18-2018, 01:08 PM | #4 |
Rep 152
Well to be honest the previous iDrive zooming direction was confusing for everyone, we all just got used to it. Clockwise to tighten/zoom in is probably more intuitive.
05-18-2018, 03:10 PM | #5 |
Rep 1,345
Drives: 04 Z4, 18 X3 M40i
You can also zoom / unzoom with a pinch gesture on the iDrive controller
Keweenawbee295.50 focker155.00 |
05-18-2018, 03:23 PM | #6 | |
Rep 825
I wonder if it is the same across all new G-models.
06-27-2018, 03:47 AM | #7 |
Rep 2
Idrive logic
I have had several Bmw’s and am used to the idrive control direction ie turn right to scroll down lists etc. My wife decided to go for a Bmw Mini and I was pleased to see it uses Bmw idrive technology. Here is the kicker though. The idrive knob in her Mini works in the opposite sense!!! Turn the knob left to scroll down. Nav zoom works in the opposite sense too. How dumb is that? Anybody know if it is possible to change the sense direction?
06-27-2018, 04:13 PM | #8 |
Rep 394
My last car (Audi SQ5) had it reversed, and I am much happier with the way the X3 does it. Just like a screw, when you turn it clockwise, it goes in, and when you turn it counterclockwise, it goes out. Why should it be any other way?
SenseiSimple9.00 |
06-28-2018, 04:17 PM | #9 | |
Rep 1,236
IMHO, the current BMW does it WRONG. When we turn the knob, a zoom scale appears. Used to be a horizontal X-Axis scale (and for Mercedes), now they change to a vertical Y-Axis scale. For most people, it is more intuitive to turn clockwise to move a X-axis pointer to the RIGHT, and a Y-Axis pointer UP. It's because we are used to turning clockwise to turn the volume up (in volume control), turn the light brighter (in rotary dimmer), turn up the heat (in thermostat), higher channel numbers/presets/radio frequencies etc. Right now, BMW makes you turn clockwise to move the Y-Axis pointer DOWN (Zoom In), which is totally counterintuitive. |
06-28-2018, 04:33 PM | #10 |
Rep 5,056
My F80 and G01 both behave the same and I think it's intuitive.
West Austin38.00 SenseiSimple9.00 |
06-28-2018, 11:08 PM | #11 | |
Rep 394
06-29-2018, 02:09 AM | #12 | |
Head Idiot
251
Rep 551
However, if people want to whinge, the G01 isn't consistent with itself. The temperature control, for example, is backwards from the iDrive controller: turn clockwise to raise (move up) the temperature, turn counterclockwise to lower (move down) the temperature. |
06-29-2018, 03:23 AM | #13 | |
Rep 394
Turn clockwise to increase zoom. Turn clockwise to increase temperature. |
West Austin38.00 |
06-29-2018, 08:54 AM | #14 |
Rep 4,577
Yes and I still go in the wrong direction sometimes.
Current: 2021 ///M3 Competition Isle of Man Green
Ordered: 2024 ///M2 Zandvoort Blue Past: 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i |
06-29-2018, 04:47 PM | #15 | |
Rep 1,236
I look at the map when I zoom in (and so do you), and on screen zoom scale axis is RIGHT THERE! There is no way to avoid it. And it totally throws off my direction as to which way to turn the knob. It is not just a physical interface, there is a visual display providing direct feedback of the physical interface. |
06-29-2018, 04:55 PM | #16 |
Rep 394
Ignore the scale and go with physical intuition. Or keep accepting the scale into your analysis and remain confused. It’s your choice.
SenseiSimple9.00 |
06-30-2018, 12:44 AM | #17 | |
Rep 1,236
And it does not help that they suddenly implement this change to opposite direction as compared with all the previous BMWs and current Mercedes that I owned. |
07-12-2018, 10:13 AM | #19 | ||
Rep 825
Headlight Knob: F10 - Off is middle and auto is far left. G01 - Off is far left and auto is middle. Audio controls: F10 - Scroll wheel up to next song G01 - Scroll wheel down to next song. iDrive Zoom: F10 - counterclockwise zooms in G01 - clockwise zooms in. Heater control (dial between hot and cold) F10 - physical dial in the center of the dash G01 - hidden behind the climate controls "menu" button. You know how long it took me to find that by accident??!!! And don't get me started on the physical buttons around the actual iDrive knob. They're all renamed and I think only back and media are in the same spot between models. WTF BMW! Did you fire Clark Kent and hire Bizarro to configure your interior button schematics???
JamieA92.50 |
07-12-2018, 10:30 AM | #20 | |
Rep 304
Drives: 2018 X3 i30xdrive
Of is there some alternate heat/cold menu setup that is needed to be accessed all the time? |
07-12-2018, 10:45 AM | #21 | |
Lateral grip estimator
959
Rep 1,390
This is so you can (for example) have cold air blowing on your face even in winter when the climate control is blowing warm air all around the cabin. In this new X3, the central face vent temperature control is buried in the idrive menu system, rather than just being a dial on the dash. Like this:
07-12-2018, 10:50 AM | #22 | |
Rep 304
Totally understand where people are coming from though... having stuff changed, however small, can be extremely annoying. I guess I lucked out, this being my first BMW. So far I can't say a bad thing about it, and after reading these forums, I've been actively looking for issues. |
Tags |
direction, idrive, map, zoom |
