08-17-2022, 09:51 AM | #1 |
Rep 38
Is this a coolant temperature sensor ?
Hello
I see some oil leak from this coolant temperature sensor i guess. Can anyone tell me what are the symptoms of it failing ? Or is it failed ? So that i can order the same part ? |
08-17-2022, 07:47 PM | #3 | |
Rep 38
08-18-2022, 05:38 PM | #4 |
Rep 352
That's actually the oil pressure switch. The only thing it does is turn on a warning light when you oil pressure drops too low. If it's leaking then by all means replace it. However it wouldn't affect drivability at all.
1986 Delphin 528e - Roof rack equipped lumber hauler.
2008 Platinum-Beige X3 3.0si - Current project 2012 Alpine White X3 xDrive35i - My new snowmobile. 2020 Estoril Blue 440i xDrive cabrio w/MPPSK - This car is a blast to drive. |
