      03-09-2019, 05:39 PM   #1
Emilr
Drives: BMW 320D Xdrive 2014
Retrofit in x3
Hello, i am thinking about to do some Retrofit in my car. Anyone that has done the sport+/eco pro switch?
done something else Retrofit?
      03-12-2019, 05:50 PM   #2
Lowill94
Lowill94's Avatar
Drives: 2013 BMW X3 X-Drive 28I
I used the bimmercode app with one of the recommended WiFi/Bluetooth dongles. I mainly did it so I could have sport mode with just chassis setting. If you search under the F30 chassis you can find a lot of very helpful tips there. Our F25 has a lot of the same software as they F30.
      03-12-2019, 07:11 PM   #3
Emilr
Oh nice, i have a man that will code my car so i can use the switch that irettofitted. Look forwads to that😀 did you feelt ant difference?
      03-13-2019, 07:34 AM   #4
Lowill94
Lowill94's Avatar
I actually hardly ever use sport+. Now on longer road trips I like to use sport mode with the sport setting to only chassis. That way my drivetrain still acts as it would in comfort mode. But the very few times I have used Sport+ it did made a difference. It pretty much just deactivated the traction control. And I also hear the turbo a decent bit more.
      03-13-2019, 08:12 AM   #5
Emilr
Do you have the switch With the gearapplicator? The sport and eco switch
      10-21-2023, 07:38 AM   #6
Lehan
Drives: BMW E90 323i BMW F25 xdrive28i
Hey I have done the switch, it’s super cool. Much better throttle response in sports, eco mode is definitely more efficient tho it is very slow and painful to drive in, it feels like driving a xdrive20i when it is a xdrive28i. You would need to run 2 wires from the switch to the ICM, it’s definitely worth it if you can get the switch for cheap from some junkyard.
