      06-30-2018, 11:23 AM   #1
AMCross
Drives: BMW F25 3.5d MSport LCI
rear window aerial bypass
anyone know if you can bypass the rear windows aerials
im getting dab no signal and apparently the screen aerials are useless anyway
could I buy a dab aerial just to test its not the head unit at fault
      07-01-2018, 04:37 AM   #2
Peter_R
Air Vice Marshall
Peter_R's Avatar
Originally Posted by AMCross View Post
anyone know if you can bypass the rear windows aerials im getting dab no signal and apparently the screen aerials are useless anyway could I buy a dab aerial just to test its not the head unit at fault
Dab screen aerials useless anyway
Never heard that one! Suggest you ask a dealer what they think before messing about with a temporary aerial.
I use DAB all the time in my area and it works all the time.
Have you tried using it with rear screen heating on for any length of time?
What is DB signal strength like in Scotland? Have you tried south?
Tried the postcode checker?
http://www.ukdigitalradio.com/covera...tails.asp?id=1
You might get more helpful answers from the following forum that is more UK orientated. Believe it or not the majority of long term posters are jocks.
http://bmwland.org.uk/index.php
      07-01-2018, 12:10 PM   #3
AMCross
yes the bmw dealer said whilst car was in that it would cost circa £150 to diagnose
just to add it comes up with bbc list of stations but all say no signal when selected
      07-01-2018, 03:07 PM   #4
Peter_R
Air Vice Marshall
Peter_R's Avatar
I am no expert (only able to tune stations ), but it sounds to me as though you are outside the signal area.
From what I remember, when I go through the occasional signal drop off area it still shows the station's name.
Did you look at the signal area map I posted in an earlier post?
Have you tried in other areas in the UK other than Scotland?
One other item I forgot to ask. Have you a 3rd party rear dash-cam fitted? These are notorious for completely blocking out the signal. It is the wiring to the front dash-cam if it is configured that way. In most cases you need to have a ferrite ring fitted to the connecting wire? Mine had to have one installed when it was fitted. BMWs are worse than most.
      07-02-2018, 01:30 AM   #5
Troppo
Keyboard warrior
Troppo's Avatar
16
Drives: X3.
No reason that the DAB antenna (LH rear window) would not work OK - as others have said, it may be a lack of signal strength in general, rather than an antenna problem...
      07-07-2018, 07:41 AM   #6
AMCross
ok guys thanks for your help
no dash cam fitted but surely just outside Edinburgh we should get a signal
bmw dealer not much help at all
      07-07-2018, 08:14 AM   #7
Peter_R
Air Vice Marshall
Peter_R's Avatar
Agreed. Did you look at the link posted giving signal areas?
      07-07-2018, 12:08 PM   #8
AMCross
right between two main transmitters as per picture
      07-07-2018, 08:29 PM   #9
Troppo
Keyboard warrior
Troppo's Avatar
16
Drives: X3.
Looks like coverage should be OK.
You know that FM actually sounds better, don't you...
      07-08-2018, 01:58 AM   #10
Peter_R
Air Vice Marshall
Peter_R's Avatar
That is very subjective.
      07-08-2018, 04:20 AM   #11
Troppo
Keyboard warrior
Troppo's Avatar
16
Drives: X3.
Not all, the codec is old, and they pack too many stations into the multiplex...
Translation: It is old tech and they tried to do it on the cheap....
      07-08-2018, 10:55 AM   #12
Peter_R
Air Vice Marshall
Peter_R's Avatar
...and FM is old tech too...
      07-08-2018, 10:57 AM   #13
AMCross
I agree with both of you
paid 2k for a Tag McLaren dab Upgrade for my hifi system was great at first but gradually got worse
but when they switch fm off what are we supposed to do if BMW cant get a reliable system in their cars
my volvo s60 was perfect
      07-08-2018, 11:01 AM   #14
Peter_R
Air Vice Marshall
Peter_R's Avatar
The experts seem to be saying that DAB+ is the way to go. Read the following:
https://www.theregister.co.uk/2018/0...re_is_not_dab/
We will have to see.
      07-08-2018, 11:09 AM   #15
AMCross
but a lot of dab units are NOT software updatedable to DAB+
      07-08-2018, 11:59 AM   #16
Peter_R
Air Vice Marshall
Peter_R's Avatar
but a lot of dab units are software updatedable to DAB+
Then go and talk to BMW! You started off this thread asking for help that many tried to do, because BMW wanted money. Now it has turned into a debate.
Many people are of the view that DAB is in many cases better than FM that suffers badly from hiss. It is not perfect in the UK. Mine works perfectly on more or less the same car as yours, and I receive many stations except in the occasional DB drop out area where everything is blank including the rubbish hissy FM.
By the way, did you purchase the car from a BMW dealer under the Approved Used Car(UAC) scheme? If so it is incumbent on them to fix!
How long have you had the car? Even if it was not AUC, it was faulty on purchase, unless it has just happened during your ownership!
      07-08-2018, 12:24 PM   #17
AMCross
no faulty on purchase but dont worry I wont bore you anymore
      07-08-2018, 03:29 PM   #18
Peter_R
Air Vice Marshall
Peter_R's Avatar
You are not boring anyone! You did not give sufficient information in your first post. If you had advised the forum that it was not faulty on purchase, then you would have been advised to seek advice from a specialist in the form of a BMW dealer or a BMW independent. Yes it will cost money. Cars go wrong as you can see and you will have to pay to have it assessed and fixed.
      07-08-2018, 07:54 PM   #19
Troppo
Keyboard warrior
Troppo's Avatar
16
Drives: X3.
They are right. DAB+ is much better.
