      11-17-2018, 07:20 AM   #1
TheCoolX3
Drives: 2016 BMW X3 35i M-Sport
Waste gate out of wack
A couple weeks ago I posted a vid of some strange noises on cold starts and light-medium throttle driving. The conclusion is that it was normal with a catless dp and the sounds were coming from the waste gate. After some research on the BMW forums i've come to the conclusion that vacuum in the waste gate somehow got screwed up and I will be resetting it following this Kies Motorsports video
I'll do this on Monday ideally. I'll post back with results if this was in-fact the culprit. I could also just be dumb and these sounds are completely normal but as sounds normally are not picked up well on video, it does not do the atrocity of these noises justice.
If you guys have done this before please give suggestions/advice. Seems like it should be a 15 minute job!
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others
Instagram @TheCoolX3
      11-17-2018, 09:50 AM   #2
hardparker
Father of Frankenfold
299
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
I've done it. It's quick and easy to do from the top. Good luck. I hope it fixes your problem.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
TheCoolX3173.50
      11-17-2018, 11:27 AM   #3
doodlebro
Drives: '17 X3 35i
I'm having some weird boost control issues and wondering if I needed to do it. I'm getting throttle closures from overboosting on BM3 Stage 1. Good to know it's easy to do from the top.
Log if you're curious: http://www.bootmod3.net/log?id=5be26c8cd10b435d53e3f516
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP
Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280'
      11-17-2018, 06:03 PM   #4
TheCoolX3
That is almost exactly what is happening to me. Im overboosting low end and underboosting top end its very strange. Ill let you know if it works!
      11-17-2018, 06:04 PM   #5
TheCoolX3
Thank you for the advice! did you remove the downpipe?
      11-20-2018, 06:38 PM   #6
TheCoolX3
Update: Went to do this. Got the top nut off of the wastegate arm with ease. I wanted to check and make sure I could access the vacuum line to the actuator before I took of the lower nut which held the wastegate's position. I could not get the vacuum line off of the actuator. Likely due to the fact that, I have large hands and there is not much access to that hose. I could get a little grip on the line but she was really on there and it was not a regular vacuum hose, it was so sort of braided line. I will be trying this again but I am currently seeking some advice.
Is it safe to use pliers to remove the vacuum hose?
How would one get the bottom nut on the wastegate arm loosened?
What size hose fits the wastegate actuator fitting?
The wastegate should be completely closed at the BMW recommended pressure of 5.9 In.Hg, is this correct?
Thank you in advance!
      11-20-2018, 06:39 PM   #7
TheCoolX3
hardparker
      11-20-2018, 08:24 PM   #8
hardparker
299
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
Pliers are okay on the hose as long as you don't damage it. I think it's 3mm hose. Yeah, 5.9 in hg to fully and firmly seat the flapper. The nuts on the rod are 10mm.
TheCoolX3173.50
      11-21-2018, 07:39 AM   #9
TheCoolX3
Thanks!
      11-21-2018, 11:43 AM   #10
doodlebro
Drives: '17 X3 35i
I'd heat the fitting up with something like a hair dryer if possible. That way it should give much easier. I have an easier time pulling vacuum lines that way.
Current mods
TheCoolX3173.50
      11-21-2018, 02:17 PM   #11
TheCoolX3
Will do thank you very much!
      12-01-2018, 03:02 PM   #12
TheCoolX3
Took the car to BMW today. Just got a call, about 5 hours after dropping it off, and they said that they could not fix it under warranty. So I am back to fixing myself.
When I went to heat up the vacuum line I noticed that it was wrapped in some nylon covering so when I heated it, the line did not expand and I could not get it off.
Any advice?
Thanks in advance
      12-09-2018, 12:08 PM   #13
TheCoolX3
Update: Did this, the wastegate arm was a bit off but it did not fix it. Still makes a hissing noise on cold start and a horrible spool noise. Looking for other fixes/Suggestions.
      12-09-2018, 03:39 PM   #14
________
________
4159
Drives: ________
New turbo
      12-09-2018, 06:15 PM   #15
doodlebro
Drives: '17 X3 35i
Yeah, I'd check the turbo fins/bearing for any play. I installed my VRSF catless and I'm not experiencing the stuff you are. I also checked my wastegate nuts and they were still very tight, so I didn't mess with anything.
Current mods
      12-09-2018, 06:33 PM   #16
TheCoolX3
I thought this too but if I put it in sport or sport plus it doesn’t make the sound nearly as loud or if at all. Which makes me think it doesn’t have anything to do with turbo fins. I still think it’s something with the wastegate but I’m not sure. I connected to the vacuum line that leads up the engine and not the actuator I don’t know if that would give me a bad reading?
      12-09-2018, 06:48 PM   #17
TheCoolX3
I will get a better video of the hissing on a cold start tomorrow. Hope that helps someone diagnose the issue!
      12-10-2018, 03:52 PM   #18
TheCoolX3
Video link for the hissing at cold start.
      12-13-2018, 08:33 PM   #19
TheCoolX3
$165 dollars spent on a new boost solenoid!! Hope that is the issue! Going to install that then reset the waste gate again. Will post back with results in a few days!
      12-13-2018, 08:50 PM   #20
________
________
4159
Drives: ________
I really hope that finally resolves your issue so you'll be able to have the 4th fastest X3 in the world.
      12-13-2018, 08:52 PM   #21
TheCoolX3
Lmao! I am only making about 13psi at WOT and ill still freight train that overboosted n20!
________4158.50
      12-13-2018, 09:25 PM   #22
x3sm
x3sm's Avatar
282
Drives: M3 E93 Porsche
oh my goodness
M3 E93
PORSCHE MACAN S: SOLD
BMW X3 F25: SOLD
AUDI S4: SOLD
BMW E92 335: SOLD
________4158.50
TheCoolX3173.50
