01-31-2019, 09:22 AM | #1 |
Rep 244
Drives: 2022 BMW X4 M40i
Coding
Has anyone messed around with coding via Bimmercode? I saw some posts in the X3 forum and was curious about it. Are there any risks to coding or anything? Is it fairly easy to do?
02-01-2019, 09:15 PM | #3 |
Rep 191
Anti dazzle does not work correctly on my '19 x4 m40i. I believe the headlights are missing components required to do it properly.
02-02-2019, 07:35 AM | #4 |
Rep 453
I think they would work on mine, when I set the headlights to automatic they slowly lower before switching to low beam when another car approaches, my last x4 was either on or off and these are a much softer effect. that's half of what anti dazzle does, the other being they open up specific tunnels of light. plus there's many on the X3 forum who have coded on their anti dazzle and it works perfectly for them.
02-02-2019, 03:08 PM | #5 | |
Rep 191
It's possible I've missed something when coding, but a friend has a '18 G01 with the exact same coding and his works fine. So BMW may now be using cheaper components in '19 models (there are plenty examples of that in other models, one guy has a car with one good headlamp and one bad one!). The headlamp part numbers are the same. I turned off the left half of the tunnel to not bother oncoming drivers, and lowered the intensity of the right to give me a little bit of extra light which is still really helpful but it's not correct behavior. |
02-02-2019, 04:20 PM | #6 | ||
Rep 3,654
02-03-2019, 10:11 PM | #8 |
Rep 6
I've used bimmercode with UniCarScan. I was able to code:
Removed Idrive disclaimer Removed camera warning Disabled driver seatbelt warning Disabled passenger seatbelt warning Removed mirror tilt Video playback while in motion Button on key fob closes trunk I tried to change the speed limit Info road sign type. That gave me an error that I had to use the backup file to revert it back. |
02-04-2019, 02:20 AM | #9 |
Rep 7
I used Vgate iCar Pro Bluetooth.
I did the following: Removed camera warning, Activated video in motion, Changed boot logo, Activated digital speedometer, Changed instrument cluster look, Added M logo to center of instrument cluster. |
02-05-2019, 08:05 AM | #10 |
Rep 244
I used the OBDLink MX+ ODB2 with Bimmercode.
I did the following: Activated video in motion Activated digital speedometer Button on key fob closes trunk Added color Red to ambient lighting |
02-05-2019, 04:29 PM | #11 |
Rep 191
NGHB can currently only be done with E-sys. You have to make around 200 FDL changes to configure the US headlamp parameters with the euro spec parameters, but enable side marker and some other settings pertaining to the actual light modules alone.
If you code the FLMs straight to euro spec by modifying the FA with the EU type, the side marker lights will go off, but they will otherwise work with no failures. But again my headlamps (in either Euro or the 200+FDL specific changes to more correctly blend US and EU spec) don't seem capable of making the correct patterns. E-sys is also very fussy with my car and often won't show the mappings when I try to edit the FDL of the BDC_BODY members or FLM. |
02-07-2019, 06:06 AM | #12 | |
Rep 455
Current: 2022 ///M3 San Marino Blue, Comp, xDrive, Fjord Blue/Black --plus-- 2022 ///M440i Gran Coupe, Aventurin Red, Cognac Vernasca
Past '20 X4 ///M Competition Toronto Red -- '16 ///M3 Tanzanite Blue, ZCP -- '15 ///M3 Mineral Grey |
02-08-2019, 03:44 PM | #13 |
Rep 244
Has anyone been able to successfully get the Alpina instrument cluster to work?
02-09-2019, 01:45 AM | #14 |
Rep 194
Is the lack of boot closure off the key fob a US thing?
Mine has opened and closed it from day one? I’ve coded Start in sports Ind ASD off Red LED lighting iDrive M start up screen Seat belt warning off (drivers & passenger) Alarm warning when locking it with engine running |
02-12-2019, 12:14 PM | #16 |
Rep 444
What does the digital speedo look like on this car?
2018 F87 LCI gone but not forgotten
2021 G80 6MT BSM |
02-17-2019, 02:24 PM | #17 | |
Rep 8,364
Mapping is not issue with car. That is memory problem, fixed by correct configuration. |
02-17-2019, 07:13 PM | #18 | |
Rep 191
I did find that VLD is off when comparing to ECE codes, and turned that on (LUT_FLC_FORWARDLIGHTING_Y and C_AFS_ENA). This car does not have 8S4 in its FA, only 5AP so that had to be done by FDL. VLD now seems to work correctly, but NGHB still produces a glaring pattern. Are you aware of others I should try? And yeah the mapping is definitely something weird with memory/eSys. It never has problems with the mappings that I've read from a G01 on an older iStep. I can usually get it to work by open those first, THEN opening mine. It's a headache but I'm eventually able to do what I need to do. Last edited by djrobx; 02-17-2019 at 07:18 PM.. |
02-17-2019, 09:00 PM | #19 | |
Rep 8,364
djrobx57.00 |
03-14-2019, 09:38 AM | #20 | |
Rep 191
LUT_FLC_FORWARDLIGHTING_Y (Eur: 00 00 14, US: 00 00 00) C_AFS_ENA (Eur: 1, US: 0) C_CLC_BLINK_ENA (Eur: 1, US: 0) C_CLC_REV_ENA (Eur: 1, US: 0) The others you've listed look to be the same, I.e. LUT_AFS_CODRV_HOR shows: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 in both eur and US spec. There are a couple other related differences with CLC though, but I think CLC is cornering lighting, so I wouldn't think it would impact NGHB? C_CLC_CURV_V2 (Eur: 23, US: 3C) C_CLC_CURV_V3 (Eur: 28, US: 46) C_BLC_PRE_ENA doesn't exist? 1DF8 also looks like it has no other differences aside from the ones we want, so we can just VO code that to ECE spec. It unfortunately does not fix the bad glare on my '19 though. -- Rob |
03-14-2019, 07:24 PM | #22 |
Rep 8,364
Which Solution are you using? E-sysX, Pro Launcher 3.2, Premium?
Tags |
bimmercode, coding |
