10-10-2020, 01:05 AM | #5 |
Rep 2,907
A 7mm hex bit is best to manually rewind the electric parking brake to change the rear pads. And you need a hex bit to remove the slider bolts on the front calipers. Most everything else on the car is torx, except the suspension likely requires some triple square bits.
10-10-2020, 02:01 PM | #6 | |
Rep 2,547
The best way rewind the e-brake is to use a scan tool to command it to go into service mode. |
10-10-2020, 03:02 PM | #7 |
Rep 211
Harbor freight. Same warranty as craftsman, snap on, ect . Break a tool exchange for a new one. I run a small shop and 75% of my hand tools are harbor and I beat the crap out of them... I very rarely need to exchange tools.
10-10-2020, 05:08 PM | #8 |
Rep 83
Tools
I have enough tools except what I would need to do the brakes and the charge pipe on my X3. This is my first German car but I still plan on doing the routine stuff. I already have a oil filter cap wrench and the air sockets to fit the lug nuts. Anything else will be done by an independent BMW shop. Thanks all for the advice, I am getting too old to spend an afternoon under the car.
Wgosma806.00 |
