      04-28-2019, 07:11 PM   #1
TheCoolX3
Drives: 2016 BMW X3 35i M-Sport
Pure Inlet and GFB DV+
Happy Sunday my fellow X3 drivers!
Wondering if anyone has done the GFB Diverter valve and PURE inlet on stock turbo for n55. Looking to get a little more spool and some cool woosh woosh noises. I've seen the GFB DV on other N55 cars and it seems like a 1 hour mod. I think the inlet would require some custom work, guys who have done it please tell me the tricks of the trade!
Thanks in advance!
Brian
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others
Instagram @TheCoolX3
      04-30-2019, 09:14 AM   #2
doodlebro
Drives: '17 X3 35i
The pure inlet is next to impossible to install on our cars. The OE inlet which you have to cut is very hard plastic and must be cut very close to the bend. Hardparker got it to work with some type of epoxy or JB weld. I went with the inlet made by AZ-MCRacer over on the F10 side of bimmerpost, but I also had to buy a new clean air pipe since the F10's is slightly different from ours.
If you want to try the Pure inlet, I have the one I tried to use and will be happy to send it over at a reasonable cost.
The DV is a quick mod if you have the turbo out of the car. Otherwise you're going to have to drain coolant + remove water pump to get access to all the bolts.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP
Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280'
      04-30-2019, 09:39 AM   #3
TheCoolX3
I may try the pure inlet because I intend to route the intake to the front of the car just behind the kidney grills, still doing some research on that. I saw a video where a guy did the DV+ on his 435i and he just removed the bracket for the water pump which gave him enough room to sneak the DV in and out.
      05-02-2019, 07:42 AM   #4
najnad
General of the Space Forces
najnad's Avatar
Drives: 11 X3 35i M-sport
Apparently there is a full pipe version of the PURE inlet that doesnt require cutting, just replaces the entire thing. Not sure if it will fit on our X3's though...
https://www.pureturbos.com/store/oem...e-f30-f10.html
      05-02-2019, 08:24 AM   #5
TheCoolX3
Sadly it will not work.. the F3X intake system routs in front of the engine while ours wraps around the side and goes over the engine.
It seems the only way to get a PURE inlet to fit, option 1 and lots of JB weld are required.
      05-03-2019, 12:44 AM   #6
n55ke
Drives: 2011 f25 3.5i
I got the e90 inlet and had a shop modify it to curve similar to oem, fitment was tight but worked
