      03-11-2023, 02:46 PM   #1
rahankuivaaja
Drives: 2016 BMW X3 F25
Running wires from cabin to engine bay in order to install LED bar
Hi,
I am installing a led bar and got the signal for relay using canm8 can-bus high beam relay. I found the proper can-wires from near the fuse box behind glove box and I am now trying to figure out how can I run the wires from there to engine bay?
The car is 2016 BMW X3 F25
View post on imgur.com
I found something (picture above) that apparently has cables inside it and goes through firewall but I don't think I can use that?
Help would be really appreciated.
Last edited by rahankuivaaja; 03-11-2023 at 02:52 PM.. Reason: added details about car
      03-18-2023, 03:01 PM   #2
littleob
Drives: BMW e36ic, 2013 x3
wiring
I installed lights and a camera in my 2013 F25 x3. Take a look under the hood, below the master cylinder. I think you will find you're in the correct place. I used a small knife like a pocket knife. Made a slit wide enough to push the snake through that plug. I caution you the smaller the slit the better then a little silicone to water tight it. I hope this helps
383vett625.50
